Gas Tank Dilema..........
Old Apr 4, 2003 | 11:38 PM
ZDADDY92's Avatar
Angry Gas Tank Dilema..........
I have been looking for a gas tank that has a removable filler neck so that it is easier to remove if need be. The stock one was a pain in the a**. Anyone out there know where to find this????? Any help is appreciated! Thanks.....
Old Apr 5, 2003 | 01:38 AM
aziroc's Avatar
do u change out ur gas tank that much??!!?? if its because of a fuel pump.. i have heard the easiest way of replacing a fuel pump is to taek the carpet out from the trunk, remove the metal heat shield and the tank is right there..
Old Apr 5, 2003 | 06:15 PM
guywidiroc's Avatar
Its easier to just put a good fuel pump in the 1st time, and forget about it.
Old Apr 5, 2003 | 06:38 PM
ZZ430RS's Avatar
There isn't a removable cover, unless somebody butchered the car before and put one in it. A lot of guys do that but if it isn't done correctly the patch could fail in a rear end collision and let fuel into the inside of the car, that's a bad thing!!!
Nayr
Mar 3, 2023 08:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
Anon
Jul 23, 2015 12:18 PM
