Iroc?
Originally posted by IZ28
Z28: 82-87 and 91-92
IROC-Z28: 85-90
The 305 TBI was the base IROC engine but wasn't all that common as most were 305 TPI's. If it's an IROC for real and an 85-87 it'll have RPO B4Z, if it's and 88-90 it'll have RPO Z28.
IROC-Z28: 85-90
its an 88 but it doesnt have rpo z28.......it also doesnt have the rpo for limited slip rear end, and it has drum brakes.....???
but on my VIN history its an iroc/z28 TBI 305..........it has the groudn effects but it doesnt say rs,z28,iroc or anything anywhere...ive found iroc emblems that look original inside the consol (prolly a poser's doings).......whats the significants of the sports coupe? is that another name for berlinetta? (keep in mind this is a tbi 305 car)
The RPO's tell you what model it is, not the VIN, unless it's a model with a specific engine, but since you have the base engine it is most likely a Sport Coupe.
88 IROC-Z: www.thirdgen.org/rides/rideimages/ACF4bocUB.jpg (with GTS headlight blackouts)
88 Sport Coupe: www.thirdgen.org/rides/rideimages/ACFbT08vU.jpg (emblems will say CAMARO, you'll have the square steering wheel, and some got the spoiler like the IROC)
as long as i dont have any trouble droppin in my 305, i have a good strong tranny (700r4) im happy.....but i have 2.73 non posi rear end...
if any1 knows where i can find a good drop in 3.73 (or somn like that) limited slip, cheap new or used, please let me know
e
i talked to the guy who owned it last, the engine i got is the one that came out of the car orginialy (tbi 305) he also said the reason it had iroc **** in it is cause he had an iroc and used it for parts... (my rpo say i have the lo3 tbi 305)
about your rear end...(not your butt! You sicko!)go to a junkyard or check on here for an 93-02 rear end from a M6 car. That way you'll get 3:42's, posi, AND rear discs! Good deal huh? O course if you do that, you need to run new lines and change the hand brake bracket...good luck!
i hate that look........would i just be able to get one from a 3rd gen t/a or an iroc? what problems should i look for if so?
If its used you can't be too picky, but try and find one with good seals. (Axles, cover and pinion) If you happen to run into alot of them with leaking axle seals or a leaky cover, don't worry those are easy to fix. If you find one with a blown pinion seal, chances are the pinion bearing is going bad.
ive been thinkin about a 350.....ive got a 305 for it but i need heads and other small things...not too much trouble (its the stock tbi 305)......IF i want/can afford a 350, would it bolt right in? on the tbi's dont the injector plug things go into the throttle body? if so would i have to customize my wire harness/injector plugs/anything else to make it work?
