intermittant shake while accelerating
Old May 28, 2006 | 10:01 PM
Black305RS's Avatar
another question here about my iroc its a 305 tpi. fairly often while i accelerate hard or soft the car shakes. i was wondering what could cause this and if new plugs/wires/rotor might fix it.
Old May 29, 2006 | 05:40 AM
iansane's Avatar
Re: intermittant shake while accelerating
Have you inspected the plugs/cap/rotor/wires for cracking, arcing, fouling, corrosion build up yet?
Old May 29, 2006 | 01:23 PM
Black305RS's Avatar
not really ive been working a lot lately and havent had time to go over the car. but i definately will thanks.
Old May 29, 2006 | 05:00 PM
IROC-T's Avatar
Might want to check the motor mounts as well.
Old May 29, 2006 | 09:10 PM
DCJLove's Avatar
Drive shaft bent or warped? But I suppose if you let off the gas mid-shake and the shake goes away it wouldn't be the shaft.
Old May 30, 2006 | 02:11 AM
Kuruption562's Avatar
Yup most likely plugs arent connected correctly, might have one switched around with another one
Old May 30, 2006 | 03:26 AM
iansane's Avatar
I think it's impossible to assume something like with the few details provided. There are tons of things it could be, hell a bad ground. Just easiest to inspect the parts that are easy first and work you way up to the more difficult stuff.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
CARiD
Sep 7, 2015 08:21 AM
