Which intake and carb combo to get
Old Jul 13, 2007 | 02:37 PM
1987IROC350's Avatar
I had all the stuff in my sig installed a few months ago.
This car will just not run with the TPI F.I. system. So I've decided to remove all F.I. stuff and buy a combo package. I miss not driving this car and it's been a year.
Which would give me the best drive as a daily driver????
If you suggest something else make sure it is for Vortec heads.
http://store.summitracing.com/egnsea...140+115+400065
Old Jul 14, 2007 | 10:56 PM
confused327's Avatar
I don't think I'd buy a combo, I'd just get a performer rpm and a vacuum secondary holley. Or if you really wanted to you could get(I think) a spreadbore perf. rpm and a Q-jet, it would probably yield better mileage.
Old Jul 15, 2007 | 01:08 AM
Angelis83LT's Avatar
Whatever you do. if you go with a non computer controlled system, don't forget chances are you will need to get a standard HEI ignition for a non computer controlled car.
Old Jul 15, 2007 | 12:39 PM
jayman350's Avatar
my thoughts exactly
i started looking through the different carbs that are listed on summit. it more or less comes down to your personal preferences. I like Holley better than Edelbrock for carbs....but i would buy an Edelbrock Performer RPM Air-Gap manifold to start out with just about any carb.
I would say go with either the Holley street avenger series or a 4160 and buy a secondary metering block and quick change spring kit. A straight up 4160 will be fine, but when the secondaries open up there is no way to control the amount of fuel w/o adding a metering block.
Old Jul 15, 2007 | 12:45 PM
mdacton's Avatar
How much do you want to spend?
There are alot of things you can do...why do you say it will not run with TPI?
Old Jul 16, 2007 | 07:54 AM
onefastgta's Avatar
Those parts in your sig are not enough to disrupt the 87 maf sensor. You must have had a combination of problems and/or didn't attempt to tune it.
Old Jul 16, 2007 | 05:40 PM
AutoRoc's Avatar
Cut a hole in the hood is step #1. I managed to fit an RPM Air Gap Vortec intake with a Demon 750 carb under my stock hood. It needs a good 2-3" drop base air filter setup but you'll figure all that out. MSD Billet distributor. Spring it for full advance at 2000-2500rpm. If you add up all the advertized HP gains, you're looking at like....9 billion hp. jk You could do a 600cfm Vac sec. Holley for a couple hundred bucks or a custom built Holley from Pro-Systems for maybe $600. The $400 extra could easily be worth it when you consider it will be tuned 99% perfectly, from idle/cruise all the way to full throttle, excellent tech support included and he has refferences as far as the eye can see. I did that option. http://www.pro-system.com/
Old Jul 16, 2007 | 07:33 PM
I fit an RPM Air gap/Holley carb under the stock hood, I didn't have to cut the supports out but did anyway just for some extra insurance. ~1" drop air cleaner.
Old Jul 25, 2007 | 04:59 PM
I just got back from the shop. The car runs great. It was the valves and distributor had a crack.
So I left the car there to get the gauges and suspension mods on. I'll get a video soon and post it.
Also thanks again to all who suggested stuff. It all worked out.
I have the BW 9 bolt that came with the car still in it trouble free. Will this 360HP engine be to much for it???
If so what should I put in it??
I'm not going to race it. Just going to cruise with it and an occasional speedburst.
Old Jul 26, 2007 | 08:22 AM
onefastgta's Avatar
Your 9 bolt should be fine. I am running 1.58-59 60 fts on mine with all the stock stuff other than a ring and pinion change.
Old Jul 26, 2007 | 03:11 PM
So what gears do you have?
I'm still running stock 3.27
Old Jul 28, 2007 | 11:16 PM
irocz28_305's Avatar
we got a z28 rear end with a 4.10, my brother has an 85 iroc that we've been workin on for 3 months were buildin a 350 for and i think his came stock with 3.42
_____________________
1982 z28
1985 iroc
soon to get
1989 iroc w/engine and tranny for 200 bucks
oldschool
Feb 9, 2016 09:21 PM
dfarr67
Apr 10, 2015 07:44 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
markaubuchon
Jan 14, 2015 01:48 AM
