inline fuel pump
Old Nov 30, 2003 | 11:45 PM
zulater91's Avatar
inline fuel pump
how would i go about putting a inline fule pump in as far setting up the sending unit. i am getting tired of droping the tank to fix a fule pump and i want more Reliability
Old Dec 1, 2003 | 02:06 AM
97WS6SCharged's Avatar
What's causing the in tank pumps to go bad?
Old Dec 1, 2003 | 12:34 PM
zulater91's Avatar
bad luck with the fuel pumps. i dont know. it just wont hold pressure, and now just recently it wont pump enough fuel. it is a after market higher pressure pump granttie. i am not sure if thats the right spelling. i hooked a gauge up to the pump from a fuel line and i am only getting 5psi from the pump, and in the rail nothing. but it turns on and runs
Old Dec 1, 2003 | 03:01 PM
kandied91z's Avatar
just plum it in line and run your standard power to it. i wouldn't say it's more reliable though. i had one and it caused alot more problems so finally i spent the extra money and got a nice walbro pump. very happy with it.
Old Dec 1, 2003 | 04:26 PM
zulater91's Avatar
when i open the gas cap i have alot of air comming out of the tank what could be the casue of that it happens every so often
Old Dec 1, 2003 | 07:25 PM
aklim's Avatar
Granatelli pumps are the Walbro ones AFAIK. I have had one and it works well. In any case, how do you know it is not your fuel pressure regulator that is shot?
Old Dec 1, 2003 | 10:07 PM
kandied91z's Avatar
if you let it run too low it can cause that...
Old Dec 1, 2003 | 10:22 PM
zulater91's Avatar
how would i know if it is the fuel regulater. i hooked up a pressure gauge to the sending fuel line and i was only getting 5psi. what do you guys think i should do next
Old Dec 1, 2003 | 11:23 PM
aklim's Avatar
DO NOT START THE CAR DOING THIS TEST.
Clamp off the fuel return line with a set of vise grips and turn the key to see if the fuel pressure goes up.
Old Dec 2, 2003 | 09:57 AM
zulater91's Avatar
i had the return line off and no fuel at all came through it. that leaves me to think that there is not enough pressure in the fuel rail to open up the regulater. some one told me the check vavle in the pump could be bad too cause it would build up pressure and then drop it.
Old Dec 2, 2003 | 10:21 AM
aklim's Avatar
Stupid question but are you getting 12V to the pump? I recall that when I hooked up a scanner, it told me how many volts to the pump but I would get a DVOM onto the pump leads.
Old Dec 2, 2003 | 07:17 PM
Zepher's Avatar
If you want to go with an inline pump, best thing to do is get a fuel pickup from a carbed car.
My car was carbed so I just put an inline pump near the back of the car and left the tank alone.
Here is a spare carb pickup I have,
Old Dec 7, 2003 | 05:10 PM
zulater91's Avatar
i hooked a battery to it and still nothing over 5psi from the pump
Old Dec 7, 2003 | 05:13 PM
zulater91's Avatar
this is the thrid pump that has gone out on me and i have no idea on why.
Old Dec 8, 2003 | 01:28 PM
aklim's Avatar
Are you getting 12V or what at the pump. I suggest you solve the problem first instead of just throwing parts at it. 3 pumps in a short time is not usually just coincidence. My stock 91 pump was replaced this year because I was changing the tank and didn't want to have to do it again to get to the pump. It was working fine.
