I want a 3rd gen What should I get
Old Oct 22, 2002 | 05:50 PM
purduetwinkie's Avatar
What can be done to a third gen 5.7 that is good as a daily driver, where can I find out more about parts and sites where they sell them. Also what third gen should I gen and why?
Old Oct 22, 2002 | 06:48 PM
MN87IROC's Avatar
Try thirdgen.org. It should have all the answers you need.
Old Oct 22, 2002 | 08:07 PM
bluirocz85's Avatar
Talking
I wouldn't settle for less than an Iroc-z. If you have to have a 350, they were made from 87 up and all were TPI's and automatic. If you want a 5 speed, a 305 will have to do, but you can always change the motor if you want.
Old Oct 22, 2002 | 08:44 PM
StealthElephant's Avatar
Iroc Z all the way.....all i gotta say is hood louvers
Old Oct 23, 2002 | 04:19 PM
19WS6T/A91's Avatar
i say go with a trans am. but then again im probably a little partial
Old Oct 23, 2002 | 11:16 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
The best and fastest ones are the 89-92 models with TPI, 4-wheel disc brakes, and dual catalytic converters. You'll find those in either 350 automatic or 305 5-speed.
Old Oct 24, 2002 | 08:39 AM
ThirdGenZ28 92's Avatar
I vote for 91-92s. Mine serves as a daily driver 22 miles each way to work and all it takes is a set of drag radials and Im ready to cut 1.7 60fts and mid 13s in good air with as little as a very mild converter, a few suspension pieces and bolt ons. The ride isnt harsh and I still get decent gas mileage for a 102k mile well abuse stock L98....
Old Oct 25, 2002 | 12:03 AM
CRZYTRN-92Z28's Avatar
Talking
91-92 Z28 w/ the L98 350, or an iroc-z
I'd at least get a 87 or up.
Old Oct 25, 2002 | 07:51 AM
96 TA's Avatar
I would say get a 91-92, The ground effects are real good looking and instead of hood louvers you'll have hood blisters which you can always take off and put the louvers in if you rather have them. Just do a search and look at both the I-ROC and 91-92 Z28 and choose what you would rather have. I like the 350 TPI but I would take the 305 TPI as well, There both good engines but again it all depends on what you want, if you want economy i would take the 305 but if you want more of a preformance engine id only take the 350. Good luck
PS. www.thirdgen.org is a great site to go to if you have a 3rd gen.
14
Aug 11, 2015 12:03 PM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
cmsmith
Jul 10, 2015 07:19 PM
cmsmith
Jul 5, 2015 07:23 PM
