i never knew there was a kit for this
Old Aug 9, 2003 | 02:20 AM
10sallday85Z28's Avatar
ok i never knew they actually made a kit for a tb coolant bypass....
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
and can someone explain to me how to do this bypass!
Old Aug 9, 2003 | 03:02 AM
Blownyellow's Avatar
The kit is made for people who don't understand the concept of the way it works.
The coolant normally comes out of you intake manifold and takes a direct turn up into the base of your throttlebody, then goes through it's passages and out the passenger side of the throttlebody and in to the heater core, then back to the rad.
What you want to do is run a line from the input of your heater core, to the coolant outlet that is on the front of your base manifold. All you are doing is taking the throttlebody out of the cooling loop, and going directly to the heater core.
Old Aug 9, 2003 | 03:10 AM
ive heard many ways to do this....
Old Aug 9, 2003 | 03:24 AM
I would be inerested to hear the other ways than what I described.
Old Aug 9, 2003 | 10:28 AM
slayer6x6's Avatar
You wont get 8 hp from it though
Old Aug 9, 2003 | 11:23 AM
Geezer powered's Avatar
and they make money of of that I might start selling ??????????????
Old Aug 9, 2003 | 02:22 PM
i heard u can either get a double ended male coupler or a really long heater hose...... which way?
Old Aug 9, 2003 | 04:27 PM
I personally used a short piece of hose coming off the intake then a 90 degree fitting, then one long heater hose going all the way to the heater core.
I don't run that stock plastic vaccum operated crappy junction on my car.
Old Aug 10, 2003 | 04:19 AM
Matt_Ky's Avatar
Could someone post a diagram of how they did the TB bypass and parts needed?
Old Jan 2, 2004 | 01:52 PM
Pro
Guest
Posts: n/a
Sorry to bring this back from the dead.... but I am curious WHY GM put this coolant design on the TPI? Do the LT1s have the same thing?
Old Jan 2, 2004 | 03:04 PM
doug791's Avatar
they did to heat the TB so if youre driving the car during the dead of winter the TB blades dont ice over.
Old Jan 2, 2004 | 03:18 PM
Pro
Guest
Posts: n/a
How could it ice over anyway unless they got wet?
Old Jan 2, 2004 | 03:21 PM
Black6SpdTA's Avatar
Yep.
Old Jan 2, 2004 | 04:37 PM
doug791's Avatar
condensation? i dont know it was a concern and this way theres no chance it could happen.
Old Jan 2, 2004 | 04:49 PM
condensation?
So only really if the car sat in a freezing place? If it was parked there for a night or two I doubt the blades could accumulate enough condensation to freeze. Hm, good thinking on GM's part I geuss. Except for us guys after every last pony
