I need help with Gaskets and Rebuild sets!
Old Oct 12, 2004 | 04:44 PM
  #16
85_305's Avatar
Re: I need help with Gaskets and Rebuild sets!
Hmm.. I will look into this "bore Micrometer".. I will see if my old tech-teacher has one; if not, I will call Autozone or something.
Old Oct 12, 2004 | 06:53 PM
  #17
Dave89IROC's Avatar
there are two normal ways to check the bore, a bore micrometer or a "t-gauge " and a regular micrometer
Old Oct 12, 2004 | 07:40 PM
  #18
85_305's Avatar
I should measure (2x each) the top, middle, and bottom of the cylander right? Which micrometer should I use, btw? Which one is more accurate?
Old Oct 13, 2004 | 02:40 PM
  #19
Tru2Chevy's Avatar
A bore micrometer will be the easiest to use, which usually results in more accurate readings.
And yes, 2x measurements at the top, middle, and bottom. (when we say two measurements, we mean take a measurement, and then rotate the tool 90 degrees and measure again).
- Justin
Old Oct 13, 2004 | 03:17 PM
  #20
85_305's Avatar
^Oh.. ok.. I just just figured it meant 2 readings just for accuracy's sake. But Jim already undid MOST of teh tranny bolts; who in the FOCK would put 2 diff. sizes of bolts on the f'in tranny?
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
