Hp numbers for a modded 305
Well I`m putting a set of heads on and intake and carb I would like to know how much power it has
The engine is a LG4 305 with the following modds
Offy Duel plane duel port intake
Holley 600 cfm carb (freshley rebuilt)
1" spacer
305 heads that have been bowl blended gasket mached and exshust ports smoothed and the intake valves are now 1.94"s
1 5/8" headmann headers
Mild street cam I have no clue how big it is or the make lets just say it`s about the size of a 305 TPI cam
Flow master muffler
And I`m going to make a 3" cowl hood too
What do you think the output might be, my guess around 250hp
1" spacer
Flow master muffler
From: Teeter-tottering between Brilliance and Insanity
I would say 280-325 on a stock bore 305. I would definetely suggest buying a new cam, especially if you dont even rally know what that one is. And the 305 TPI cam is wimpy, you can go a little stronger than that.
The Factory Hp number is 155hp
I was thinking of changing the cam but I need to pass one more E-test so I don`t want to go to anything wild the intake and carb are easy to change to stock again but cams are not
And for those who are thinking put a 350 in I`m building a 383 I just want to make more power with the 305 till I get the 383.
Oh yeah I also have a 14X3" K&N filter
and besides he said its comparitive to it...
Originally posted by MY91Y84
depending on the 305 were talking about...the g92 LB9's got the L98 cam
I might be looking at a crane Energizer 260 H10 cam
Specs:
Dur. 260
Dur. 204@.050
Lift in/ex .427
lob sep. 110*
RPM range 1200-4200. Which is allright since my red line is 5000
It says it`s 50 state legal so you think I could pass an E-test with it right?
It wont mess up my vacuum right?
And would it give me alot more power with this cam with my setup? I would like to be in LT1 territory
I don`t what to spend $300 for 5 more hp. If it give 15-20 or more I`ll get it if not then I`ll stick with what I have
Specs:
Dur. 260
Dur. 204@.050
Lift in/ex .427
lob sep. 110*
Specs:
Dur. 260
Dur. 204@.050
Lift in/ex .427
lob sep. 110*
Specs:
Dur. 260
Dur. 204@.050
Lift in/ex .427
lob sep. 110*
That equals more hp and torque.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
