Hp numbers for a modded 305
Old Aug 10, 2003 | 05:13 PM
Chris`s85Z28's Avatar
Well I`m putting a set of heads on and intake and carb I would like to know how much power it has
The engine is a LG4 305 with the following modds
Offy Duel plane duel port intake
Holley 600 cfm carb (freshley rebuilt)
1" spacer
305 heads that have been bowl blended gasket mached and exshust ports smoothed and the intake valves are now 1.94"s
1 5/8" headmann headers
Mild street cam I have no clue how big it is or the make lets just say it`s about the size of a 305 TPI cam
Flow master muffler
And I`m going to make a 3" cowl hood too
What do you think the output might be, my guess around 250hp
Old Aug 10, 2003 | 06:17 PM
Geezer powered's Avatar
what was the hp stock first off.
Old Aug 10, 2003 | 06:20 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I would say 280-325 on a stock bore 305. I would definetely suggest buying a new cam, especially if you dont even rally know what that one is. And the 305 TPI cam is wimpy, you can go a little stronger than that.
Old Aug 10, 2003 | 07:48 PM
The Factory Hp number is 155hp
I was thinking of changing the cam but I need to pass one more E-test so I don`t want to go to anything wild the intake and carb are easy to change to stock again but cams are not
And for those who are thinking put a 350 in I`m building a 383 I just want to make more power with the 305 till I get the 383.
Oh yeah I also have a 14X3" K&N filter
Old Aug 10, 2003 | 09:52 PM
1fastformula's Avatar
Unhappy
those mods will probably net you 185 to 195 rear wheel. Which translates to 225-235 at the flywheel. BUILD YOUR 350!!!!
Later
Old Aug 10, 2003 | 11:00 PM
MY91Y84's Avatar
depending on the 305 were talking about...the g92 LB9's got the L98 cam
and besides he said its comparitive to it...
Old Aug 10, 2003 | 11:28 PM
yeah 250 fwhp is about right give or take 15hp
Old Aug 11, 2003 | 01:12 AM
DarthIROC's Avatar
Even comparable to it, isnt really enough. TPI cams werent all that. You could go with something a little tougher. I agree you dont want one as big as mine for a 305, I wish I knew then what I do now. I would have been more sensable with it.
Old Aug 11, 2003 | 09:20 AM
I might be looking at a crane Energizer 260 H10 cam
Specs:
Dur. 260
Dur. 204@.050
Lift in/ex .427
lob sep. 110*
RPM range 1200-4200. Which is allright since my red line is 5000
It says it`s 50 state legal so you think I could pass an E-test with it right?
It wont mess up my vacuum right?
And would it give me alot more power with this cam with my setup? I would like to be in LT1 territory
I don`t what to spend $300 for 5 more hp. If it give 15-20 or more I`ll get it if not then I`ll stick with what I have
Old Aug 11, 2003 | 08:08 PM
Sitting Bull's Avatar
Specs:
Dur. 260
Dur. 204@.050
Lift in/ex .427
lob sep. 110*
Even though you have done your heads, chances are that the exhaust side can use even more help. Thus I would recommend the Crane PowerMax 260 or 266. Or the Comp Extreme Energy 256. All of these cams offer a higher lift and longer duration exhaust lobe and will really help the exhaust gases get the heck out of Dodge
That equals more hp and torque.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
markaubuchon
Jan 14, 2015 01:48 AM
