how tight for the oil drain plug
Old Jul 13, 2003 | 02:17 PM
CamaroZ28Coupe's Avatar
i dont want to strip my threads but i also would like to stop the leak from my drain plug after i changed the oil could someone let me know how tight i should torque the oil pan drain plug? thanks
Old Jul 13, 2003 | 02:32 PM
1fastformula's Avatar
Thumbs up
Get you a new plug with a nice little gasket on it....That would stop it cold!!!!
Do not over torque it....Break the head off and then you have some work ahead of you
Later
Old Jul 13, 2003 | 04:17 PM
TheGreatJ's Avatar
Agreed. If you get it good and tight and it still leaks, replace the nylon washer or get a new plug. You DO NOT want to risk breaking it off or stripping the threads out of the pan, because you basically have to pull the motor to get the oilpan off these engines.
Old Jul 13, 2003 | 06:02 PM
Damon's Avatar
Yeah, new nylon washer time. Think: 1/3 as tight as a spark plug.
Magenta_Hearts
Mar 29, 2017 08:54 PM
KYWes
Apr 15, 2015 07:11 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
