how to step up the power for a 1989 formula 350 but stay reliable
Old Dec 9, 2005 | 07:03 AM
  #16
91-Z28-L98's Avatar
Re: how to step up the power for a 1989 formula 350 but stay reliable
http://www.stealthram.com/ For the answers to all of your stealth ram questions.
Also, I'll explain the throttle body coolant bypass. In order to keep the intake air heated, chevy has routed a coolant line through the bottom of the throttle body. This probably has an upside (if you live in Montana in the winter) but in most cases heating the intake air hurts performance since hot air is less dense than cold air. To do this mod, simply remove the two short hoses that connect to your throttle body and replace with one hose (90 degree bend, 2" on the short end, 10" on the long end) that connects from just under your thermostat housing to your heater valve. http://www.thirdgen.org/newdesign/te...ntbypass.shtml This in an article from thirdgen.org that may explain it better than I.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
linz
Oct 22, 2015 07:59 AM
XtremeLt1
Sep 13, 2002 08:50 PM
