How much would you pay for this ride
An 85 TA with the following mods:
Pros
SLP runners
Edlebrock TES
Open cat
Flowmaster Catback
TPI Airfoil
Hypertech Cap and Chip
3.23 rear end
4 wheel disc
GM performance parts tranny w/shift kit and approx 5000 mi
Regular maintence
Hasn't been raced or dogged out
Cons
Needs paint
New interior
approx 150,000 mi on motor and rear end
light smoke at start up
#7 plug gets fouled after about 4 mths
Pros
SLP runners
Edlebrock TES
Open cat
Flowmaster Catback
TPI Airfoil
3.23 rear end
4 wheel disc
Regular maintence
Cons
Needs paint
New interior
The light smoke after startup is prolly due to bad valve seals, and that sounds likely for the amout of miles that are on the motor, hopefully its just the #7 leaking bad. Otherwise It could be that the rings are shot on the #7 and that is why it fouls out after 4 months. I would find out how much oil it burns, and do a compression check before you get yourself into a mess.
It doesn't consume much oil at all. About the normal for a high mile 3rd gen. How long does a 3rd gen rear last before it fails. He hasn't had any problems with the rear. What would I need to do a lt1 swap, would the tranny be able to hold up.
Formula Steve
Sep 19, 2023 08:31 AM
RX Speed Works
Oct 1, 2015 10:19 PM
Sep 18, 2015 03:46 PM
Aug 28, 2015 07:53 AM
