How much can my t-tops hold
Old Aug 5, 2003 | 07:10 PM
sheetsyz's Avatar
hello everyone, just want you to know i have been getting on this site for a couple of years now and this site is awesome. I currently just recieved a 90 RS with t-tops and wanted to find out how much power this car will be able to handle with the t-tops. I know i will need some sub frame conectors. I also wanted to know is there anything else to help this car deal with the t-tops. My plans for the car will be a stout 350 or 383 with around 450 Hp.
Thanks for any info you can give
Old Aug 5, 2003 | 07:20 PM
Black6SpdTA's Avatar
Welcome to the board! T-top cars can hold just about the same amount of power. All you'll need for support of the car is SFC's (you already know that though). Good luck man! Out of curiousity, what kind of trans is in the car?
-Rippin
Old Aug 5, 2003 | 07:33 PM
sheetsyz's Avatar
Thanks for the reply rippin, looks like my plans will be ok for the power. It has the 700r4, and i have heard that those trans are a little shorter in the V6 cars so that will have to be tossed out. I would love to put a t56 in but not sure how that would work with a motor not running off of the computer.
Old Aug 5, 2003 | 08:01 PM
TheGreatJ's Avatar
Ahhh....the oh-so-popular 6-speed swap. Rippin is in the process, a couple of guys are planning it, 2 people I can think of will finish it in the next few days (not sure if Z-Ghost and Momar post here though) and there are guys like me who did it so long ago that we have trouble driving automatic cars now. Any questions you have, we can answer.
FWIW the T-56 has no use for the computer. The only real electronics in my car are the stereo, the speedo, and the ignition module. The T-56 VSS does require an electronic speedo but your '90 has one so it's not a problem. You'll just have to convert the signal (not difficult at all.)
Let me suggest Alston subframe connectors. Unlike most SFC's, they directly connect the front and rear subframes, instead of running down the edges of the unibody. IMO it's a better design. However, for even MORE strength, it is possible to run both types of SFC's (i.e. Alston subframe-subframe and Spohn perimeter type.)
Old Aug 5, 2003 | 08:05 PM
Geezer powered's Avatar
Well besides sub frame's look into a 6 point roll bar.or even kenny browns autocross cage.Its not for roll over but for strenght.
LT14LIFE
Nov 15, 2015 06:22 PM
PopoFormula
Oct 12, 2015 04:19 PM
CARiD
Sep 30, 2015 05:44 AM
Z Power
Sep 19, 2015 11:19 PM
