How To Make 5.0 A 5.7
Old Dec 5, 2004 | 02:29 PM
camarokidirocz's Avatar
Exclamation How To Make 5.0 A 5.7
HOw do i convert my 5.0 tpi to a 5.7 litre tpi????
Old Dec 5, 2004 | 02:46 PM
aklim's Avatar
Re: How To Make 5.0 A 5.7
Remove engine, drop in 350.
You are not working with much of an engine since the car is an old one so why bother? Get a freshly worked on long block and stick on your manifold.
Old Dec 5, 2004 | 03:47 PM
Stephen 87 IROC's Avatar
Stroke is the same. Other than that everything needs to be changed. You can't bore a 305 block out to 4.0" to make a 350 any more than trying to bore a 350 block out to try and make a 400. The 305's bore size is just too small. You can drop a stroker crank into it and make a 334.
If you want a 5.7, you need to find a 350 engine.
Old Dec 5, 2004 | 07:19 PM
82355's Avatar
Stroke is the same, but the crankshafts are actually different. They have different counterweights because of the increased weight of a 350 pistons.
Martin
Old Dec 6, 2004 | 07:43 PM
Chris9450's Avatar
In order to make a 305 a 334, it would cost as much(most times even more) than putting a 350 in, and even if you went with a 334 you still wouldn't have as much performance as a 350 with the same amount of money put into it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
dale3in98
Feb 14, 2015 12:18 PM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
92ragtop
Dec 27, 2014 01:56 PM
