How do I tell if I've got bad piston rings?
Old Aug 25, 2003 | 07:12 PM
96cam4ro's Avatar
My car smokes during start up (most probably valve seals) but it also starts smoking profusely when you just leave it to idle for prolonged periods of time (like 20-30 minutes). If you drive it and then let it idle periodically (i.e. Mcdonalds drive through), no smoke comes out.
If it's just the valve seals, I'll go with Vortec heads..if it's the piston rings..I'll go for an engine swap (expensive).
I need info for the next big thing. Thanks.
Old Aug 25, 2003 | 07:24 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Do a compression check, if a cylinder comes up low on compression you either have bad rings or pistons or both
Old Aug 25, 2003 | 08:32 PM
96cam4ro's Avatar
So will good compression indicate that my piston rings are alright eventhough I have bad valve seals?
Old Aug 25, 2003 | 09:29 PM
slayer6x6's Avatar
If you get low compression on one cylindar, then squirt a few drops of oil in the cylindar. If the compression goes up then that means that your rings are goin bad, if the compression stays the same that means you have a burnt valve, blown head gasket, etc.
Old Aug 26, 2003 | 09:48 AM
aklim's Avatar
Wouldn't a leakdown test be more revealing?
Also, with compression test, the cylinders must come out to about the same within 10% of each other.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1963SS
Feb 6, 2015 10:05 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
