How to do a fuel injection to carb conversion
Old Feb 26, 2003 | 06:21 PM
egarnaat's Avatar
I was wondering what you would have to do to convert a fuel injected 305 to carburated.
Old Feb 26, 2003 | 07:34 PM
TheGreatJ's Avatar
A lot of stuff. You have to regulate the fuel pressure down, get a non-computer distributor, carb intake, carb, air cleaner, and basically rewire the entire engine compartment. If the car has an electronic speedo that won't work anymore because it runs through the EFI computer. You have to set up a manual torque convertor lockup if it's an automatic. You have to fabricate throttle/kickdown cable brackets. Your cruise control won't work.
I know all this because I have done it.
The advantages are: if you're taking out TBI then you'll gain some power, it'll clean up the engine bay and make it much easier to work on, and engine mods will suddenly seem very very cheap by comparison. Go ahead and change the cam since you have the intake off anyway, and it might be worth it.
beltrunner
Apr 15, 2015 01:10 AM
Sauced
Mar 29, 2015 10:53 PM
Jubjub
Mar 19, 2015 10:23 AM
Brady
Jul 29, 2002 10:30 PM
Z-4-ME
Aug 13, 2001 10:35 PM
