Houston we have a problem!!!!
I hear a whinning noise when I accelerat! Sound like its coming from my rear end! What could this be? I had the rear end bearing kit installed about 3 yrs ago, do they wear down that quickly....WTF! I baby the car, i never drive it hard.
Re: Houston we have a problem!!!!
What all would i need to do a rear end rebuild with gear swap? Will the pkg from Thunder Racing be enough? I need help asap, i don't wanna be stuck overe here. Any tech articles would be great also!
The diff is easy to replace if you are keeping the same gears. Just unbolt the old one, remove the ring gear, put the ring gear on the new diff, and pop it back in.
- Justin
- Justin
If you're going with the Thunder Racing setup I'd call them up. They have treated me well in teh past. As for how hard it is? Well, I wouldn't attempt it and I have redone my motor 3 times and done countless other things like a T56 swap into an A4 car. Its somthing that should usually be left to the professionals. I paid $600 for a complete swap from 2.77's to 3.73's.
mark0006
Feb 3, 2015 05:12 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
