Hotchkis SFCs
Old Jul 12, 2004 | 03:26 PM
V8Rumble's Avatar
Question Hotchkis SFCs
Hey guys, just wanted to find out if anyone had any experience w/ Hotchkis SFCs or not. Are they better, worse, or about the same as most of the others?
Thanks!
Old Jul 12, 2004 | 04:01 PM
87DJP2001's Avatar
Just my opinion I went Spohn Performance for SFC's, Rear LCA's and Panhard Bar just so I would know everything would fit. Very good Quality on all the tube type pars. For your info I do have a Hotchkis STB, which I also like.
Old Jul 12, 2004 | 05:31 PM
Zepher's Avatar
I'll let you know in a couple of months how the Hotchkis ones are. I've got a set ready to put on, but I need to finish the car first.
Old Jul 12, 2004 | 07:02 PM
V8Rumble's Avatar
Thanks for the responses guys. I'd love to go w/ the Spohn parts (have heard good things about them), but I don't think that Summit carries that brand, & I've got $100 in Summit gift certificates that I need to use...
Zepher - have you crawled under your car & "test fitted" them? If so, did you notice anything good/bad??
Anyone else have any actual experience with them??
Thanks!
Old Jul 12, 2004 | 09:37 PM
Wishmaster's Avatar
I used to have a set but I had to sell them cause they would not fit with on the passenger side because of my header Y-pipe. so I just went with a set of MAC's....in due time I'll also get a set of Spohn's..
Old Jul 13, 2004 | 09:58 PM
V8Rumble's Avatar
CRAP. That means that they probably won't work for me either, since I have SLP 1-3/4" headers on my car...
Old Jul 14, 2004 | 01:13 AM
Zepher's Avatar
I am running long tubes with a dual exuast setup. Dual exhaust isn't built yet.
I haven't test fitted them, basically took them out of the box and put them on a shelf.
Old Jul 14, 2004 | 07:00 AM
87DJP2001's Avatar
Thats why I said Spohn SFC's worked for Me. I have SLP 1 3/4" Headers and SLP 3" Catback Exhaust. Forget the other brand and use your Sumitt cash on Hotchkis STB there. Just my opinion.
Old Jul 14, 2004 | 08:49 AM
V8Rumble's Avatar
Yep, I agree, it is a good idea - except that I can't use an STB with my StealthRam intake...
Thanks though...
Old Jul 14, 2004 | 08:53 AM
91RSLT1's Avatar
Mine fit just fine. I am about to put on a set of coated hooker 2055, so I hope I don't have any clearance issues. I like them but it is the only brand that I have had experience with, so who knows.
Old Jul 14, 2004 | 07:12 PM
V8Rumble's Avatar
Let me make sure I'm hearing you correctly - you've used Hotchkis SFCs with SLP headers?? (EDIT: Whoops, never mind. Just saw in your sig that you've got Edelbrock headers...)
Might eventually do like some others I've heard about, & have two sets - one "inside" (closer to the driveshaft tunnel) & one "outside" (closer to the outside of the car)...
Heck, come to think of it, I've just bought a MIG welder, that might be a good project...
Old Jul 16, 2004 | 07:36 AM
Wishmaster's Avatar
When I said mine wouldnt fit because of my Y-Pipe.....I think it may be due to having Tri-Y headers. The Y-pipe is so much diffferent than a regular pipe.....do I search for Tri-Y's at thirdgen.org and you can see a pictures of the funky *** pipe.....
THe Hots may fit with regular pipes.......
Old Jul 16, 2004 | 03:29 PM
Ucantcme57's Avatar
I went to spohn for my subframe connectors.. I got the torque arms and the sperical lca's.. Spohn has good quality parts.. I went through S&W for the the roll cage however because the spohn one goes in front of the dash, where I wanted the cage to be in the dash, close to the a pillar out of sight kinda and not in my way as much as it could be
ImNraged
Aug 19, 2018 08:02 PM
Slayer
Aug 17, 2015 03:55 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
