Hotchkis SFCs
Hey guys, just wanted to find out if anyone had any experience w/ Hotchkis SFCs or not. Are they better, worse, or about the same as most of the others? :confused:
Thanks!:thumb: |
Just my opinion I went Spohn Performance for SFC's, Rear LCA's and Panhard Bar just so I would know everything would fit. Very good Quality on all the tube type pars. For your info I do have a Hotchkis STB, which I also like.:D
I'll let you know in a couple of months how the Hotchkis ones are. I've got a set ready to put on, but I need to finish the car first.
Originally posted by 87DJP2001 Just my opinion I went Spohn Performance for SFC's, Rear LCA's and Panhard Bar just so I would know everything would fit. Very good Quality on all the tube type pars. For your info I do have a Hotchkis STB, which I also like.:D Zepher - have you crawled under your car & "test fitted" them? If so, did you notice anything good/bad?? Anyone else have any actual experience with them?? :) Thanks! |
I used to have a set but I had to sell them cause they would not fit with on the passenger side because of my header Y-pipe. so I just went with a set of MAC's....in due time I'll also get a set of Spohn's..
Originally posted by Wishmaster I used to have a set but I had to sell them cause they would not fit with on the passenger side because of my header Y-pipe. so I just went with a set of MAC's....in due time I'll also get a set of Spohn's.. CRAP. That means that they probably won't work for me either, since I have SLP 1-3/4" headers on my car... :irk: |
I am running long tubes with a dual exuast setup. Dual exhaust isn't built yet.
I haven't test fitted them, basically took them out of the box and put them on a shelf. |
Originally posted by V8Rumble :mad: :mad: :mad: CRAP. That means that they probably won't work for me either, since I have SLP 1-3/4" headers on my car... :irk: |
Originally posted by 87DJP2001 Thats why I said Spohn SFC's worked for Me. I have SLP 1 3/4" Headers and SLP 3" Catback Exhaust. Forget the other brand and use your Sumitt cash on Hotchkis STB there. Just my opinion. Thanks though... :) |
Mine fit just fine. I am about to put on a set of coated hooker 2055, so I hope I don't have any clearance issues. I like them but it is the only brand that I have had experience with, so who knows.
Originally posted by 91RSLT1 Mine fit just fine. I am about to put on a set of coated hooker 2055, so I hope I don't have any clearance issues. I like them but it is the only brand that I have had experience with, so who knows. Might eventually do like some others I've heard about, & have two sets - one "inside" (closer to the driveshaft tunnel) & one "outside" (closer to the outside of the car)... Heck, come to think of it, I've just bought a MIG welder, that might be a good project... ;) :D |
When I said mine wouldnt fit because of my Y-Pipe.....I think it may be due to having Tri-Y headers. The Y-pipe is so much diffferent than a regular pipe.....do I search for Tri-Y's at thirdgen.org and you can see a pictures of the funky ass pipe.....
THe Hots may fit with regular pipes....... |
I went to spohn for my subframe connectors.. I got the torque arms and the sperical lca's.. Spohn has good quality parts.. I went through S&W for the the roll cage however because the spohn one goes in front of the dash, where I wanted the cage to be in the dash, close to the a pillar out of sight kinda and not in my way as much as it could be
