Hi guys, I need help!!!!
Old Apr 24, 2005 | 06:17 PM
  #16
91z28man's Avatar
Exclamation Re: Hi guys, I need help!!!!
Ok Ok, I guess I went a little big. But i just want that racy sound chug chug u know. What about this kit:
http://store.summitracing.com/partde...=KeywordSearch
Or just a roller cam from crane what would I have to do to get this to work!
Old Apr 24, 2005 | 07:40 PM
  #17
bubba353z's Avatar
Now you're in the right neighborhood.....
Take a look at the Comp Cams 303/304/305 for computer controlled vehicles:
Comp Catalog
Page 146. Those are nice, moderate cams - I'm running the 305.
I'd stick with the roller cams - they may cost more, but will make more power. You're already set up for it, so might as well take advantage.
Old Apr 24, 2005 | 07:45 PM
  #18
91z28man's Avatar
I was thinking the compu cam and getting a chip burned for it. So all I need is a single roller cam, and the stock pushrods and lifters set up for roller will be fine.
Old Apr 24, 2005 | 07:55 PM
  #19
bubba353z's Avatar
That will work. You'll get a nice power bump and still be able to drive it daily. You can reuse the roller lifters and pushrods, with this cam. Check the mfg. valve spring requirements for any new cam. You should be OK with stock springs, but I won't swear to it.
Old Apr 24, 2005 | 10:34 PM
  #20
91z28man's Avatar
Cool, would the 306 be too big.
Old Apr 25, 2005 | 11:27 AM
  #21
bubba353z's Avatar
It would be OK with a Stealth Ram or a heavily modded TPI + exhaust + Stall convertor. A lot of guys are running them.
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
