Hesitates when I punch it
Old Nov 5, 2003 | 10:10 PM
splinter_cell's Avatar
I just got an 84 Z-28. It has the 305 Lg4 motor. whenever i punch it from a stop it hesitates. it will lunge forward then bog down then lunge forward and so on. any suggestions for me. thanks.
Old Nov 5, 2003 | 10:21 PM
TheGreatJ's Avatar
Sounds like a possible vacuum leak, or maybe the Q-jet just wants a rebuild/readjust. Also since you just got it, put new plugs/wires/cap/rotor/fuel filter/air filter/oil and filter in it just on principle. Also check the timing.
Old Nov 5, 2003 | 10:30 PM
Ok, I did plugs, wires, cap, roter, fuel filter, air filter, oil and filter. and the timing was good. Im guessing it is also a vacuum leak. I want to replace all the hoses since sum of them are bad. I have never adjusted a carb before. How would I go about in doing that?
Mike
Old Nov 9, 2003 | 03:43 PM
Marc 85Z28's Avatar
You could try doing a search on these boards as this topic comes up VERY often. Or, go to www.thirdgen.org and goto the Tech Articles.
Old Nov 9, 2003 | 05:20 PM
aklim's Avatar
Does the carb have a TPS? If so, could that be bad?
Old Nov 9, 2003 | 06:15 PM
Marc 85Z28's Avatar
Yes it does. But it isn't as important on the carbed cars as it is on the FI cars. The problem is in the secondaries, and requires adjusting of the secondary air valve spring tension, choke pull-off canister, and secondary fuel metering - all of which are explained in the Tech Articles
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
