Help with removing and IDing some Emissions stuff.
Old Jul 16, 2013 | 09:34 AM
BLACK Z !'s Avatar
Hi, I removed most of the Emissions stuff from my Car after switching over to Non Comp controlled carb and dist.
What can I do about the charcoal canister? there is also something in front of it that has vacuum and a bracket I think it is for Cruise control which I don't use or need either. Then in the lower fender area there is a Round thing with vacuum,
Can all of these be removed?
What are they for?
What do I do with the vac hoses?
Old Oct 10, 2013 | 08:16 AM
FIRECHICKEN57's Avatar
Re: Help with removing and IDing some Emissions stuff.
As far as I recall everything but the round ball can get tossed. The round ball in a vacuum reserve for things like brakes and what not.
Also I'm pretty sure one of the lines off the charcoal canister is a vent line for the fuel tank so make sure that isn't plugged. Some sort of low pressure valve would be ideal. Or at least a check valve
DirtyDaveW
Dec 1, 2016 05:37 PM
69z-28
Jan 29, 2016 10:46 PM
timmy39120
May 2, 2015 05:12 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
