Help Please Tach Bounce Pwr Loss
Old Mar 15, 2004 | 11:06 AM
SUPERMARINE's Avatar
92 305 TBI AUTO TRANY. HERES THE PROBLEM MY TACH BOUNCES LIKE A FREGGIN BOUNCY BALL IN 500 RPM INCRAMENTS AND THE CAR LOOSES POWER UP HILL. AND IT IS VERY JERKY WHILE ACCELERATING AND CRUISING BUT NOT ALL OF THE TIME I WOULD SAY ABOUT HALF THE TIME NOWSINCE I PUT IN NEW PLUGS, ROTOR, CAP AND COIL SINCE THE TACH GETS ITS SIGNAL FROM THE COIL THE NEW COIL HELPED QUITE A LOT BUT IT STILL DOES IT ABOUT HALF OF THE TIME INSTEAD OF ALL THE TIME. I RUN 93 OCTANE IN THE CAR. AND I HAVE A 160 DEG THERMOSTATE IN THE CAR. ANY HELP WOULD BE GREAT PLEASE HELP. I JUST BOUGHT A PERFORMANCE CHIP FOR THE CAR I NEED TO PUT IN IS IT A PAIN IN THE BUTT TO REMOVE THE ECU THATS 1 THING I HAVE NEVER DONE TO A CAMARO!
Old Mar 15, 2004 | 11:55 AM
1984camaroz28's Avatar
hows your plug wires..... check your plugs to
Old Mar 15, 2004 | 12:27 PM
WIRES ARE GOOD OR SO THEY SEEM ABOUT 30 OR 40 K ON THEM BRAND NEW AC DELCO PLUGS, THANKS
Old Mar 15, 2004 | 10:09 PM
aklim's Avatar
Please stop shouting.
How are the wires on the coil? Any loose?
Old Mar 16, 2004 | 12:49 AM
IROC-T's Avatar
Did both simptoms start at the same time? They may not be related,and do you remember if the problem may have started after the thermostat change ? I see alot of people useing the 160* and haveing problems(yeah 25 poeple will say they run them ok with no problems),thats to cool for the ECU so you tend to run rich.
Old Mar 16, 2004 | 02:53 PM
Marc 85Z28's Avatar
90% of the time this symptom is caused by bad plug wires. It was for me, even though the wires were literally brand new. Put in a new set of high quality wires. AC Delco wires are better than anything but MSD. The AC Delco's are reasonably priced too, only around $45 for a direct fit set.
Old Mar 17, 2004 | 12:58 AM
aklim's Avatar
Run the car at night and spray water mist at the plug wires. If it lights up, there is you problem.
Old Mar 17, 2004 | 06:38 PM
hey guys thanks a lot i bought some delco wires and guess what problem all fixed!!! thanks a million.
Old Mar 18, 2004 | 10:13 AM
Marc 85Z28's Avatar
Nutty's96
Dec 21, 2015 06:25 AM
LazyLemming
Aug 29, 2015 07:36 PM
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
techstar
Aug 6, 2015 11:20 AM
