help me pick my mods
Old Aug 5, 2003 | 08:09 PM
lordmetalz28's Avatar
Smile help me pick my mods
well looks like winter is approaching. this means storage for most camaros and for me i want to be damn fast when i come out in may. i need help on what i should do i know most of you are gonna say throw a 350 in but besides that issue help me out. i have an 87 305tpi with 700r4. i have already done the following= Ram air from the fog lights directly to the filtes which are highflows. I have added an AirFoil. i Have added jet power pulleys with no smog pump or air conditioning. I have a full accell tune up including cap rotors wires and rapidfire plugs. i have bypassed my coolant from the t/b. and i have gutted my cat and added a flowmaster catback. here are my ideas for the winter. I was gonna buy hooker shortie headers with no a.i.r also add a tpis big mouth intake manifold with siamiesed runners, portedplenum,and 52mmtb. while it was opened i was possibly if money allowed me to to add a good cam and good set of complete heads thats my 1st idead. number 2 i was gonna add the lt1 intake manifold and headers and thats all i have i need some feedback on what you guys would do to a 305 i know i should replace the motor and am thinking about so help me with the 305 and not 350 change thank you
Old Aug 5, 2003 | 08:16 PM
Geezer powered's Avatar
Heads and cam sound like a good idea,but I think a supercharger is the way to go on that 305.Get a nice intercooler on there with a small 50 shot of nitrious to keep air temps down and you will be running fast. A must with the headers.
Old Aug 5, 2003 | 09:09 PM
CamaroZ28Coupe's Avatar
i know your lookin for answers to your question but i have one of my own for you how are you gonna get around inspection when it comes time? i ask because i want to do something similar
Old Aug 5, 2003 | 09:20 PM
doug791's Avatar
Question.....what is different between the 350-305's as far as heads, intake??? i know the cam is different. I ask because heres my plan for the winter with my 350. Either buy a short block or just accomplish the same thing by buying a block and installing a rotating assembly. I am not even sure if this is possible yet but i was hoping that i can do this and then just bolt up the rest of my stock accessories ie cam, heads, intake because a good 383 bottom end is going to run me a good bit of cash. That way i have an awesome 383 base with crappy heads and intake but then i have a wicked motor to build from. Have no idea if itd work for you (or even for me?!?!?) but its just a thought.
Old Aug 5, 2003 | 09:37 PM
Well im lucky enough to live 15 miles away from the boardring counties for emmisions i dont have to pass emissions. plus if it ever came down to it my guitarist in my band has already vouhed he will pass anyone who is building thier car he dosent believe in these bull**** laws. now as for supercharging my car i will need to do all my listed mods first correct? or if i stick it right on it will be so much power i wont have enough compression to run it and my motor will literally crumble under all that stress . But the small shot of nos has crossed my mind any other ideas
Old Aug 5, 2003 | 09:44 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Buy a Stealth Ram, it will be cheaper than adding a big mouth manifold and all that. You will get TB, plenum, and intake. I think the only thing extra you have to buy is a Holley Fuel Rail.
Then get a new PROM burnt. Exhaust is always a good idea, but make sure you get a set of headers that has the hole for your O2 sensor (SLP maybe) SUbframe Connectors, and a shift kit stall convertor for your tranny.
I really dont suggest staying with the 305, and while yor spending money you might as well just buy a new shortblock.
Old Aug 5, 2003 | 09:55 PM
the holley steath ram kit goes for 3800$ in jegs the intake runners and plenum are llike 800 bucks maybe a grand with headers is there anywhere that has the holley system for a cheaper price.
Old Aug 5, 2003 | 09:57 PM
can somebody explain a stall converter and shift kit in dummy terms for me and prices to ( to let you know all your posts are really really helpful and im appreciating every minute of this)
Old Aug 5, 2003 | 10:16 PM
DarthIROC's Avatar
Lol the stealthram only goes for that much, for someone whose not already fuel injected. Your Already TPI, I think everything you need will run about $500
A stall convertor raises the RPM your tranny can take before it starts putting power to teh driveshaft. So with a higher than stock stall convertor you can launch at higher RPMs. Depending on the stall you want 250-500 dollars
A shift kit will just make your tranny have snappier shifts. Probably less than $100
Old Aug 5, 2003 | 10:20 PM
so all i need is the maniofold the plenum and the throttle body for that holley system. my stock injectors work with it i have the wiring needed etc etc etc if so its done thats what ill do this winter can you link me to place that sells this youve been very helpful
Old Aug 5, 2003 | 10:22 PM
DarthIROC's Avatar
You need their fual rail too. Your injectors will work but you could use some bigger ones. After you recover from spending on the intake it would be a good idea to upgrade injectors. Im not sure who sells it but if you look on Summit of Jegs website they probably have the option to buy just what you need without the computer and everything.
If not Im sure someone will post a link for ya.
Old Aug 5, 2003 | 10:37 PM
doug791's Avatar
heres one place that has it...scroll down the tinyest bit and its right there click me and right now "10% Off Holley Stealth-Ram Intake Manifolds and Fuel Rails when purchased together!" Theyre moving their warehouse so they have discounts all over the place.
Old Aug 6, 2003 | 08:36 AM
G-Racer's Avatar
You wil only get partial efficiecy from any of those mods if you don't have a good porting job done on your heads. I offer that service.
Old Aug 6, 2003 | 11:28 AM
DarthIROC's Avatar
Not if he buys aftermarket heads
Old Aug 6, 2003 | 10:28 PM
i need a good complete head thatll work well with the holley ram system and i dont really want to have to buy anything i just need complete heads
