Headman Headers?
Old Nov 24, 2003 | 09:06 PM
  #16
IrocSS85's Avatar
Originally posted by 85_LG4
For a 305, shorties should be fine.. not much differance between shorties and longtubes I don't think.
I agree, except when your trying to get the most out of the 305. as in if your doin alot of bolt ons. (or more)
if you get the shorties, then jegs sells a ypipe for them that will bolt up to your stock exh(or aftermarket catback). but Ive heard of problems w/the pipe not lasting very long before they rust through. (the ypipe, not the headers tubes).
zepher, my true duals end at the rearend, then just dump down. so I have approx. 30"s of tube, then the muff.s, then dumps down. I have some pics of it here.
http://f1.pg.photos.yahoo.com/ph/iro...xhaust&.view=t
i have traded the turboII muff.s for bullets. so I went from too quiet to too loud. for normal muff.s, you have to clearance up the floorpan under the rear seat cushions to make enough room. there is a few inches of space under the rear seat cushions. the bullets dont need any clearancing.
at normal ride height, there arent any ground clearance issues. now that I lowered the front end w/cut v6 springs, its close, but i have yet to hit anything. and I REALLY lowered the front. too much really.
Old Nov 24, 2003 | 09:22 PM
  #17
85_LG4
Guest
Posts: n/a
Is there "noticeable" diff. between shorties/longies?
So "is" it hard to achieve true-dual setup on a Camaro?
What exactly are Bullets? Aren't they just mufflers, but are round and long, opposed to being short, but wide.. correct?
Old Nov 24, 2003 | 09:38 PM
  #18
IrocSS85's Avatar
bullets are like oldschool cherry bombs. but w/better sound. they are hollow in the middle. as in you can look right through them. like I said, they are pretty loud. theres usually 15plus horsepower to be had w/longtubes over shorties. depends on how "built " it is. the more powerful the eng is, the bigger the diff. is.
duals are not hard to do, you just need to find a shop that will do it. and do a good job of it so they dont hang down low. mine is very tucked up and out of the way.
Old Nov 25, 2003 | 07:38 AM
  #19
97WS6SCharged's Avatar
Bullets get very annoying on a daily driven car. They are usually very loud at idle and just obnoxious (don't know if I spelled that right??) when you're on the expressway. I would check with the cops and see what kind of noise you're allowed to make or you might be getting tickets for your bullets.
Old Nov 25, 2003 | 08:56 AM
  #20
ktm520's Avatar
i've had the hedman shorties and hedman y-pipe on my car for 6 yrs now, and neither has rusted through.
Old Nov 25, 2003 | 08:28 PM
  #21
85_LG4
Guest
Posts: n/a
Aren't cherry-bombs nice? Or are they obnoxious also?
BTW 97WS6.. good spelling on "obnoxious"
Old Nov 26, 2003 | 12:50 AM
  #22
S. Holley's Avatar
Long tube headman on mine...with duals.... they POP alot... but work...
I looking to get super comp1 3/4...one day... should pickup 15-20 with them....
Old Nov 26, 2003 | 03:11 AM
  #23
Still not sure if I spelled it correctly, but seeing that it's 4:00 AM I don't really care.
Don't get me wrong, a bullet is like nothing else when you stab the loud pedal, but you get alot of cabin noise, not to mention every cop within 3 miles will be on your @$$.
I had a pair of flowmaster mufflers on my 77 Z28 that were the single chamber racing mufflers (30 series maybe?) with a 45 degree dump on the mufflers themselves that were pointed kinda between the ground and the sides of the car (sounds like a good idea when you're 17). In sand or the rain you would see dust/water jetting from the sides of the car. That idea lasted about a month and then it just go old, especially when you take your girl out and you can't hear what she's yelling at you about (maybe that was a good thing?). Cruising down the street at night, or through the parking lot at work was always a trip cause it would set off car alarms 30 feet around it.
Old Nov 26, 2003 | 03:48 AM
  #24
nape's Avatar
Haha, I did the same thing with my '78 Nova 4dr. Car looks like hell, but it sounds pretty cool
Old Nov 26, 2003 | 01:17 PM
  #25
85_LG4
Guest
Posts: n/a
Would bullets make my Camaro sound like that Challenger from
2-Slow 2-Gay, or not quite?
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
