Headlight conversion?
Old Feb 10, 2005 | 07:33 PM
JSkeet's Avatar
I know this isnt engine related so I feel a bit of guilt, but... I know some of the 3rd gen guys only hang out in this forum so here goes:
I've seen a few cars 82-92 on websites (none in real life) with a Monte Carlo headlight conversion... does anyone have a link or more detailed pictures? I was thinking of giving it a go. Once I get the '84 back on the road and it becomes daily transportation again, I hate driving in the rain at night and I've driving a late 80's Monte at night w/ no problem.
thanks guys!
Skeet
Old Feb 12, 2005 | 11:10 AM
85_305's Avatar
Re: Headlight conversion?
I believe that Monte's have the same headlights as Camaro's, lol.
Old Feb 12, 2005 | 07:52 PM
JSkeet's Avatar
i know for a fact i've seen this mod done on 3rd gens... Im pretty sure there's a sealed beam larger single light that replaces the two lights that is standard on Camaros.
its like one larger longer flat headlight.
Old Feb 13, 2005 | 02:41 AM
nj85z28's Avatar
pretty sure its the same lights as the monte carlo....my 87 monte had the same lights as my 89 RS i think
Old Feb 13, 2005 | 09:54 PM
Irocvette355's Avatar
Yep...same lights...
Old Feb 13, 2005 | 10:02 PM
TheGreatJ's Avatar
They changed the Monte headlights in like 90 or so from the two sealed beams to a larger single unit. They only had it the new way for a couple of years. I've seen a 3rd gen or two with this swap, but I don't know anyting about it.
Old Feb 13, 2005 | 10:25 PM
90rocz's Avatar
The Newer Monte's weren't sealed beams but rather the plastic shell with the bulbs going into the back. They are prone to "hazing" from heat and that makes them dimmer than the 4-light sealed beams on earlier Monte's and F-Bodies.
I have NO problem in the rain, You probably have them set too high which gives you more distance when not raining, but in the rain it will NOT reflect back off of object as well.
You can buy headlight "Aimers" that suction onto the bulb for adjustment or have a shop set them correctly for a minimal fee...
Old Feb 14, 2005 | 07:58 PM
JSkeet's Avatar
i know they are set a little high but honestly, you're the first person to say you have no problem driving in the rain at night. I've owned the car 3 years and driven other 3rd gens as well, even the Firebirds w/ the flip up lights w/ nothing blocking them from hitting the street have some issues w/ providing adequate lighting. I know the swap i've seen was with a sealed beam, I want to think it was probably a 4x9" light??? maybe a sealed beam light from '90's pickups or something similar. Guess i'll find it sooner or later
Old Feb 14, 2005 | 08:57 PM
iansane's Avatar
I'm surprised at the responses here. The later model headlights are one piece as opposed to the maros two piece design.
Look here, here...nevermind, just look here as well.
Old Feb 14, 2005 | 10:37 PM
90rocz's Avatar
Like I said, IT IS A COMPOSITE (Plastic) UNIT with bulbs inserted from the rear. The one in the Monte and the White-flamed Z are original Monte pieces, the ones in the other Z's I'm not familiar with. They look like custom fab jobs.
(Note the hazed housings on the Monte and the white-flamed Z..)
I'm not sure how going from 2 sealed beam glass bulbs to 2 insert bulbs in a plastic housing will improve your night driving...and you can't adjust each bulb individually either???
(Oh, I currently own 3-thidgens: '90 IROC tpi, '86 TA tpi, '86 Camaro coupe Mpi, no trouble with any in rain..)
Old Feb 14, 2005 | 11:08 PM
JSkeet's Avatar
omg, thank you sooooo much!! lol thats exactly where I first seen this modification done too!
iansane you're the man!
Old Feb 14, 2005 | 11:17 PM
JSkeet's Avatar
90ROCZ I dont like you....
and the I really dont think the '86-'88 Monte LS lights are plastic...
Old Feb 15, 2005 | 09:05 AM
LandryP's Avatar
The 86-86 monte LS lights are definately glass lenses with a plastic back where the bulbs twist in. I hit one from an 87 with with a golf club recently when I cleaned out my basement and it was glass
Old Feb 15, 2005 | 09:23 AM
Z28SORR's Avatar
You could also do what all the forth gen. guy do and replace the lights with aftermarket ones.
Old Feb 15, 2005 | 11:06 PM
iansane's Avatar
Not a maro, but like this?
http://img.photobucket.com/albums/v5...s/IMG_1443.jpg
