headers vs. starter
Old Mar 27, 2003 | 09:47 PM
STANGeatinZ's Avatar
headers vs. starter
I've having a problem with my starter being in the way of the headers i'm trying to install on my trans am, and i was wondering if anyone has had the same prob. and what ya'll did about it.
thanks
Old Mar 27, 2003 | 09:54 PM
Momar's Avatar
What headers do you have? There is always the option of a ministarter.
Ben
Old Mar 27, 2003 | 09:57 PM
I just got the plain headman hedders, i was told that i could get a starter for a 4.3 s-10 and everything would be fine but i really don't want to have to buy another starter
Old Mar 27, 2003 | 10:00 PM
Momar's Avatar
Are they long tubes or shorties? As far as the starter are you haveing problems getting it past it or will the header not sit against the block right with it? LT1 starters also work.
Ben
Old Mar 27, 2003 | 10:04 PM
they're long tubes and i'm having a prob. getting past it. it's too big.
Old Mar 27, 2003 | 10:27 PM
Momar's Avatar
I have the hooker long tubes, and I had to unbolt the starter to put the headers in. Also, with long tubes you almost always need a ministarter. I was told that I would need a ministarter, but I was able to fit the stock one. I have an LT1 starter now that I plan on putting in though because the end of my starter is touching one of the primaries.
Ben
Old Mar 27, 2003 | 10:33 PM
i guess i can try taking the starter out, putting the headers on, and then putting the starter back on.
thanks Momar
Old Mar 28, 2003 | 07:48 AM
87DJP2001's Avatar
After you get your stock starter and headers installed and think everything is great . Look out for the dreaded Header Problem .....HEAT SINK...
Old Mar 28, 2003 | 09:49 AM
HardDriver's Avatar
Yep, I went through "heat soak" after installing my TES Edelbrock headers. After my stock starter would not crank until it cooled down I went with a mini Hi-torque unit. Problem solved and I got to admit that it sounds really good turning over.
FredM
May 28, 2015 04:28 PM
ModdedNerd
Feb 5, 2015 04:37 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
