Head options...
Old Nov 23, 2003 | 07:46 PM
87Z's Avatar
87Z
Head options...
I have an LG4, and I was looking into some different heads for the spring if I can find a good deal. I saw somewhere that someone had used stock L98 heads on the LG4. Is that possible? I know I can find stock L98 heads cheap
Old Nov 23, 2003 | 07:54 PM
Black6SpdTA's Avatar
If you use 350 heads, one of two things happen:
A) Your compression goes in the toilet
B) You have to get them milled and then if you ever put them on a 350, you're compression is once again--in the crapper. Also I *think* you might experience some "shrouding" because of the larger chambers
I've heard good things about the W/P SR Torquer heads. Check em out, Summit has them.
Old Nov 24, 2003 | 03:42 PM
Sitting Bull's Avatar
Re: Head options...
Just port and polish your LG4 heads. They are 081, 416 or 601 castings. Regardless, just follow the link at the end of my sig for the low-down on the cheapest and fastest heads for the buck$ anywhere
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
