head light adjustment
hi again--
was wondering how in the world to adjust my headlights (low beams)..was driving around this evening and they seemed like they criss crossed about 4 feet in front of me....the car just came from the body shop and apparently they didn't realign them right when they put everything back together..i found the three screws on top of the housing, which i assume are part of the process...am i missing something at the bottom??any help would be greatly appreciated...sinjin89r/s
there are 4 screws that hold the headlight into the socket and it sounds like you found 2 of them. the three screws you found are
2 of them hold the headlight in the socket (the outside ones)
the middle one tilts the head light up or down,there will also be one on one of the sides of the head light that controls left and right. same with highbeam.always finish the adjustment by turning the screws clockwise then they will stay tight.make sure you check and adjust your high beams.
