Head Gasket Coolant holes?
Old May 19, 2004 | 10:48 PM
WhiteKid's Avatar
Alright I got my new valve springs on and I just layed down the new head gasket to make sure the holes all lined up and were correct. Well....On the block there is a huge hole, about an inch, above the center of the cylinders. Im almost positive they are coolant lines but on the gasket the holes are like 1/4", is this correct? I was worried so I dug through the garbage and got my old gasket and it was the same way. Why would there be a huge hole with only a small hole in the gasket? Thanks
Old May 19, 2004 | 11:11 PM
Pneumatic_Tire's Avatar
Well, if the old ones were the same, and the car ran fine, I wouldn't put too much concern into it. Good luck!
Old May 19, 2004 | 11:29 PM
90rocz's Avatar
Yes, that's correct...
But say, if you were building a 400 smallblock, the block, gasket and heads all need holes that lined up for steam...some 400 gaskets and don't have holes and must be drilled, as due a lot of heads.
Old May 20, 2004 | 01:03 AM
WhiteKid's Avatar
Sounds good....Thanks alot.....Im gonna be pulling an all nighter in the garage tonight....Hopefully being able to drive my car down to Ocean City, MD Friday for the car show.
Old May 20, 2004 | 01:10 AM
Well, good luck and have fun in Ocean City.
Old May 20, 2004 | 12:37 PM
TheGreatJ's Avatar
The holes in the gasket are smaller to restrict the coolant flow. If the coolant flows too fast it doesn't pull out engouh heat and the engine will overheat. Also, if there's no resistance to the coolant flow at the front of the engine, it will all flow through there instead of circulating to the back of the block (since the inlet and outlet are both at the front of the block.)
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
