hard starting the Z???
Old Jun 9, 2004 | 11:26 PM
Osmosis's Avatar
i went to start my Z today and it did not want to turn over? I had to feather the throttle to get it going. My car normally is a turn key bam engine rumbles nice. Now, I have to feather the throttle and it is running like it is missing or someting? I have no codes, but it is running rich, i can smell it?
H E L P PLEASE
Old Jun 10, 2004 | 12:07 AM
Pneumatic_Tire's Avatar
My Z does this too, but I know why. My Quadra-Bog attacks me in the wee hrs. when I go to leave in the morning. I find if i give the gas peddle about 4 good to -the-floor pumps, it will start right up. I changed the fuel filter, replaced the air cleaner, gave it new plugs, wires, cap rotor, and set the timing. The carb needs rebuilt. As for your problem, I know ask this. When did you last tune up the car, or simply change the air filter?
Old Jun 10, 2004 | 12:14 AM
Osmosis's Avatar
it' s a tpi motor. Just changed everything. Plugs, cap, rotor, wires grrrrr! Last year i changed the fuel pump/filter???? can't figure this one out?
Old Jun 10, 2004 | 12:52 AM
Do a fuel pressure test, and if that checks out, do a fuel injector test on all injectors. Good luck.
Old Jun 10, 2004 | 12:58 AM
Osmosis's Avatar
I checked injectors and the ohms are in normal limits. I plan on doing a fuel psi check tomorrow. Hoping that the AFPR has gone bad....not hoping but hoping to find the problem
Old Jun 10, 2004 | 01:17 AM
aklim's Avatar
Ground a spark plug and see if it is a blue flame.
Old Jun 10, 2004 | 09:49 AM
jmac86iroc's Avatar
if it is your fuel pressure it should be up to about 45 psi to start, at least thats what i heard.
Old Jun 10, 2004 | 09:58 AM
Osmosis's Avatar
OK, I have fuel comming out of my fuel pressure regulator. Think that is the problem.
Old Jun 10, 2004 | 01:14 PM
aklim's Avatar
Sounds like a torn diaphragm. Looks like you need a new FPR.
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
