Hard to start
Old May 28, 2006 | 09:57 PM
Black305RS's Avatar
Hard to start
My 89 iroc 305 tpi takes a while to start. it just cranks and cranks and eventually after mayber 10-15 seconds finally comes to life. this is a fairly new problem since i got the car last thursday. its been happening for about 2 days. i know the alternator is going since it generally reads under 13 volts on the gauge and was wonbdering if a weak battery could cause the car to take longer to start. or what if any other reason there could be for this and possible solutions.
Old May 29, 2006 | 11:11 AM
teke184's Avatar
Re: Hard to start
first thing to do is get the alt checked, as well as the battery. any auto parts store should be able to tell you what's going on with those 2 parts.
could be a fuel problem as well.
i would get the charging stuff checked out or replaced.
then go through and do a full tune up....plugs, wires, cap, rotor, fuel filter...and see what happens.
Old May 29, 2006 | 01:22 PM
Black305RS's Avatar
Re: Hard to start
i just tested my battery today at work it came up bad i was wondering if the lo9w charging voltage could be caused by the bad battery and if the alt could still be good.
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
