Gutting the Airbox, Need to mount the air sensor
Old Apr 17, 2003 | 01:48 PM
firebirdjosh's Avatar
I was told that the sensor on my air box in my 1989 Firebird is an air temperature sensor. I want to remove my air box and stick an open air filter in. How can mount the air temperature sensor further down the pipe without it falling off and sucking in dirt, ruining my engine?
Old Apr 17, 2003 | 11:23 PM
fbird95's Avatar
You need to put it closer to where the actual air enters the air box. Not only does it give a more accurate reading, it does the same thing as the SLP temp sensor relocator. I have heard different opinions on if it actually does anything, whether you bought the slp part or just did it yourself.
Old Apr 18, 2003 | 07:32 AM
irocz8957's Avatar
how was it mounted in before??
Old Apr 18, 2003 | 10:13 AM
It is mounted to the side of the airbox. The sensor is a little clip that plugs into the mount on the airbox. I can get a picture if needed. I am just so cared of moving it and having it fall out and stuff goes in the hole it was once in.
Old Apr 18, 2003 | 10:24 AM
Lungz's Avatar
well if you are worried about that, weld in a screw fitting or a plug fitting and the problem is solved, just simulate the way it was in the airbox.
Old Apr 18, 2003 | 02:53 PM
Damon's Avatar
If you're going with a conical filter you could just drill a hole in the rubber end of the filter (the far end of the filter) and shove it in there. Otherwise, anywhere in the pipe between the filter and the engine will do just fine, as long as it's sealed up reasonably well. Drill a hole in a flat area of the pipe, put it in, seal it and hold it in place with a little smear of RTV.
Is this a V6 car? TPI V8s had it screwed into the bottom of the intake manifold. TBI V8 cars had it in the back of the TB or screwed into the intake, I think.
Old Apr 18, 2003 | 05:44 PM
Dave89IROC's Avatar
TBI cars had it in the bottom of the air cleaner, towards the pssenger seat from the tb
Old Apr 18, 2003 | 09:47 PM
Mine's a 6. I don't know if it is TPI or TBI either. So what works best for sealing the sensor into a pipe?
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
95chwagon
Jan 13, 2015 09:19 PM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
