got another tranny
Old Dec 22, 2004 | 10:54 AM
rat-at-tach's Avatar
got another tranny
well out of about 10 wrecking yards that i phoned i found a camaro tranny for $250.00 cdn,so cross your fingers and wish me luck.
the guy couldnt give me any info on it he had a few camaros in there and forgot which one he pulled it from.
oh ya the rebuild price on my old one was $1500.00 cdn plus tax
Old Dec 22, 2004 | 02:00 PM
aklim's Avatar
Re: got another tranny
Hope it is going to last. What torque converter is coming with it or are you reusing your old one?
Old Dec 23, 2004 | 12:32 AM
FruityOne's Avatar
While its generally considered a bad idea to re-use your old converter you can get away with it in certain situations.
If you know for sure that you only fried clutch material then its no biggie. It'll get cleaned out by the filter.
However, if you chewed some metal pieces up then you'd best not re-use that old converter as metal peices can get by the filter and into your fluid easy enough. Then you have to worry about the metal chunks tearing the clutches in the new tranny to bits.
I reused the the TC from my old tranny on this new built one. The old tranny's governor cover plate had slipped and i lost nearly all the fluid. When I went to downshift passing a truck it went into 2nd gear and destroyed the band. I had so much clutch material in my pan the magnet couldn't even hold it all.
1,000 miles on the new tranny and there aren't any indications that anything is wrong. Fluid looks great, and the tranny shifts quick and firmly. built trannies with shift kits are a wonderful thing.
BTW, I rebuilt the tranny in my car myself. About a weekends worth of work, including the shift kit install.
Old Dec 23, 2004 | 11:59 AM
the one i got came with the tc and the gut told me to use that one so thats what ill do insted of risking it.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
