good 305 cam
Old Mar 19, 2004 | 08:55 PM
Chris`s85Z28's Avatar
good 305 cam
I need to put some more power into my 305 for it`s last summer so I need to know what would be a good cam for my combo
Specs:
305 LG4 stock bottem end
305 heads Stock with bowl job and gasket matched w/1.94 in
Edelbrock Perfomer EGR intake
Q-jet or Holley 600
Headers
Flowmaster muffler
K&N 14X3 filter
My Zed is a 5 spd w/3:23 posi
I was looking at the 265DEH Comp cam
Dur: 265/269 in/ex @.050 211/221 in/ex
Lift .442/.465 in/ex
LSA 110
will this cam work or will I have to modd the heads for the extra lift?
Old Mar 19, 2004 | 10:30 PM
Sitting Bull's Avatar
Re: good 305 cam
Specs:
Q-jet or Holley 600
Headers
Flowmaster muffler
K&N 14X3 filter
LSA 110
You'll be on the ragged edge of your lift limit, so I'd go one step smaller. The Comp XE256 will work nicely.
I use the Crane PowerMax 260 (.427 and .454) and it is excellent, even in -20* Celsius weather. Lots of grunt right up to 5000 rpm.
Old Mar 20, 2004 | 09:14 AM
I checked out the 256H and it looks like a nice cam.
They have a dyno sheat that shows a 356sbc made 330hp and 411 ft lbs
modds where:
perfomer intake
Dart S/R heads
Holley carb
1 5/8 headers
So I`m guessing around 250 hp and about 300 ft lbs with my 305?
Old Mar 21, 2004 | 07:36 AM
Yes, that would be close, maybe more with your parts.
Old Mar 21, 2004 | 02:30 PM
jcurrieirocz's Avatar
would that same cam fit in my 87 lg4 (stock roller engine i think)
im running identical mods to him except no intake yet(will be going in with a cam when i do it) and no head work.
my rear and tranny is the same.
but i got the 87 centerbolt engine.
Old Mar 21, 2004 | 05:30 PM
Yup.
Old Mar 21, 2004 | 09:25 PM
dosent a 87 up sbc need a roller cam?
Old Mar 22, 2004 | 01:06 AM
Yes it does need a roller cam.
He should phone Comp or Crane at their 1-800 number to get their advice on it.
Old Mar 22, 2004 | 01:13 AM
RS Dragster's Avatar
What's wrong with a used LT1 cam?
Maybe he's got too many mods for that, but I know I put one in my 88 Camaro and it definately woke her up.
Just throwing that out there
Old Mar 22, 2004 | 01:59 AM
Big Als Z's Avatar
Im going to install the ZZ4 cam in my LB9. Im actualy doing it right now(types with greese coverd hands)
The ZZ4 specs are... damn it.. I always forget, but its better then the 2 cams listed here. Ill find the specs or someone will post them. I will probably have to due some PROM tuning, but I should be able to get by for a bit till I start to really get into the whole prom tuning deal. Im also going with a set of ported stock heads with stiffer valvesprings, and perhaps I might go wtih a 1.94 intake valve. The ZZ4 cam is pretty cheap, you can get them from engine builders who buy the ZZ4 and rip the cam out for more power. The ZZ4 is a great cam for the 305, and its a roller cam.
Old Mar 22, 2004 | 09:10 AM
Sure, LT1 cams are a good buy and seemingly plentiful. Just be prepared to run an electric fuel pump on a carbed engine if the cam has no fuel pump lobe.
Old Mar 22, 2004 | 12:19 PM
StalkerIROCZ's Avatar
I put the Comp cam in my 305TPI that is .449 int .456 ext. I am real close to putting the engine back in and am on the edge of my seat i cant wait BUt i called comp and they Told me it was a good cam for a stock engine with ported heads.
Old Mar 23, 2004 | 09:22 AM
anyone got any good links on cams "with prices" or seen any sweet deals on roller cams for my carbed lg4.
Im still debating whether i sould run a elec fuel pump for the lt1 cam as i seen these for cheaper. Im ganna be getting a new carb and intake so i guess a fuel pump wouldnt be too much more would it??? What psi should i be running on it???
oldschool
Feb 9, 2016 09:21 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
