Gas Smell
Old Apr 13, 2003 | 01:27 AM
Ryknow86's Avatar
Gas Smell
Hey ive only oned my first Z28 for about 3 days now. When i drive it the interor smells like gas, and when i get out i reak like gas. Is this somethin that always happens with the third gens? if not whats the problem? thanks
Old Apr 13, 2003 | 10:52 AM
thezisking's Avatar
My buddy had that problem with his 87 Iroc. The reason his did it was because somebody changed his fuel pump but didn't want to drop the gas tank, so they cut the body above the tank (Inside the hatch). Go into your hatch and pull the carpet up and check if it's leaking in back there. Just an idea for ya.
Old Apr 13, 2003 | 01:39 PM
fbird95's Avatar
It could be you evap canister leaking into the HVAC system under the hood. Is it coming in throuh the vents, or firewall?
I had this problem in my 95, luckily the evap canister is behind the rear wheel well so i only smelled the gas outside the car.
Old Apr 13, 2003 | 08:57 PM
Ryknow86's Avatar
yes, i only smell it when i drive it hard, when im just crusin and shiftin at low RPMs its not too bad, when i really give it hell i smell it alot.
Old Apr 14, 2003 | 07:43 AM
irocz8957's Avatar
i would check the fuel pump like that other guy said, ive heard of that happening before!
Old Apr 14, 2003 | 08:06 PM
Ryknow86's Avatar
its not a really strong smell just a little bit. the more gas i give it the worse it smells, it dosent do it all the time, but if i run it hard i smell it. Its got a Holley carb on it, i dont know if that has somethin to do with it.
Old Apr 14, 2003 | 08:53 PM
TheGreatJ's Avatar
Sounds like your carb is jetted for cold weather. When it gets warmer (i.e. now) the air becomes less dense which makes the car run rich. You need to tune your carb.
Old Apr 15, 2003 | 06:52 PM
white91z28's Avatar
I had the same problem with my camaro. the cause is that their are tiny holes in the gas tank filler neck. this is caused by age and gasoline. There was a recal on our cars for that problem. so i went to my local chevy dealer and they replaced my whole entire tank and filler neck for FREE.
Old Apr 15, 2003 | 09:22 PM
ICEmanZ's Avatar
i have a similar problem on my '87 Z28, but gas actually leaks from the back of the car(back by the gas tank, off to the one side-the driver side of the car i believe)... the hotter out it is the more it leaks. i hardly have a problem with it in the winter, but in the summer it's a pain in the ***. i have found a way to prevent the gas from leaking though... once i park my car after driving it i get out and open the gas cap about half to let the pressure out and i leave it half way open until i get in to drive it again, but before i leave i close the cap... this IS a pain in the *** but it seems to stop it from leaking most of the time. BUT this only works if i have less then half a tank of gas, otherwise there is no pressure to let out, therefore my car leaks gas. so it seems like as long as i keep the tank under half and let the pressure out after driving, it's fine, but otherwise my tank will leak.
WHAT IS WRONG?
Old Apr 17, 2004 | 03:22 PM
DanTheIROCMan's Avatar
Did this recall affect 89 350 TPI? If so, how do I go about pursuing this?
Nayr
Mar 3, 2023 08:34 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Bails098
Aug 17, 2015 05:15 PM
