gas gauge problem
Old Jul 31, 2003 | 09:18 PM
WHITE91ZCAR's Avatar
gas gauge problem
hey need some help my gas gauge is all the way past full exept when it is empty then it goes to e any ideas?
Old Jul 31, 2003 | 09:20 PM
Black6SpdTA's Avatar
So it stays at full, then just drops right to E at the same time you run out of gas?
Old Jul 31, 2003 | 09:31 PM
i got about 10 miles before it runs out
Old Aug 1, 2003 | 04:01 AM
Kuruption562's Avatar
Yeha i got problems with my Gauge too. When i Brake it goes down aswell as the Temp.
Old Aug 1, 2003 | 07:57 AM
87DJP2001's Avatar
Replace the gauge. They fail before the sending unit.
Old Aug 1, 2003 | 02:55 PM
POS Camaro's Avatar
I think its the sending unit.
I hate to contridict people, but my sending unit went bad and I had the same type of indication. Mine at least went to 1/4 vice empty.
There is a connector under car between the rear fire wall and the gas tank. Disconnect it and take an ohmmeter reading on the sending unit. If it is higher than 150 ohms (infinity or in the megohm range), the sending unit is toast.
If you can get a resistance box, plug it in to the guage side of the connector and adjust from about zero to around 150 ohms. If you need the exact range, ask and I'll look it up. The needle should respond to the resistance input (ignition in on or no electron flow).
I made a 200 ohm box to test this and other sending units. Its not too bad to create. Radio Shack has all the parts.
DetroitZ28
Feb 13, 2015 07:33 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
blac94Z
Nov 24, 2014 07:12 PM
slothgrant
Aug 22, 2002 03:01 PM
simple
Aug 11, 2002 11:56 AM
