FUEL PUMP REPLACMENT PART No ?
Old Nov 29, 2004 | 02:04 AM
kozikot's Avatar
Can't hear the pump anymore !!!!!!!!, fuel filter empty !!!, pushed some gas down the fuel line outlet at the filter,fired up first time, fuel pump goosed ?
Want to check the fuse and or relay first,you never know,can someone point out the location of the fuel pump fuse and relay ? If,and as I, and everyone on here suspects it's the dreaded pump, what's the recommended replacment, Make and part No please,Trap door option seem's the easiest,any down side's ? Many Thanks in advance.
Old Nov 29, 2004 | 08:58 AM
aklim's Avatar
Re: FUEL PUMP REPLACMENT PART No ?
http://www.autoperformanceengineering.com/ and go to the pump section.
I wouldn't cut the floor pan. It is the easiest way but it leaves a hole there. You are only doing this once, or so you hope so do it right. Take the tank out and see if it is rusted anywheres. If so, get a new tank. Ask me how I know.
Old Nov 29, 2004 | 11:39 PM
splinter_cell's Avatar
aklim what exactly needs to be done to replace the intank pump?
Old Nov 30, 2004 | 01:29 AM
aklim's Avatar
You need to take a trip to the local GM store. Get the straps that hold the tank in place because they will probably be rusted in. You also need the gasket that holds the ring and the pump assembly and of course the pump. Siphon as much gas as you can and have the tank empty if possible. Drop rear axel a bit till you can clear the tank out.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
