Fuel, I think.
Old Sep 22, 2003 | 01:55 PM
smurdogg's Avatar
Fuel, I think.
I ran out of gas. I'm an idiot. Now with gas, and fuse checking, and jumping, it wont start. It's an 87, fuel injected. You know that sound of when you turn it to run without cranking-I've always thought it was the fuel pump-it wont make that sound now. Any imput would be great. I wish I had some better news for my first post.
Old Sep 22, 2003 | 03:29 PM
Pro
Guest
Posts: n/a
Im willing to bet that the fuel pump burned up. As far as i know, the gasoline surrounding it keeps it cool, and obviously if you drive it until the tank is empti-fied...
Old Sep 22, 2003 | 04:12 PM
smurdogg's Avatar
thats a shame. why am i such an idiot?
Old Sep 22, 2003 | 05:06 PM
aklim's Avatar
I really don't think it plays such a great role. I have run out many times when my gage wasn't working right or I wasn't paying attention and the only reason I replaced the stock pump was that I was changing the tank after 12 years.
I would suspect that it was either a coincidence or the pump was on it's last legs and that pushed it over the edge, if it was the pump.
After it runs out, it is harder to start because the fuel rail must get filled and presurrized again. Check the fuel pressure first.
Old Sep 22, 2003 | 05:48 PM
lordmetalz28's Avatar
first off use your head on this one meaning try the easiest thing first. 99 percent chance your filter is clogged solid if not just for ****s and giggle cheack the relay then you know for sure its your pump
Old Sep 22, 2003 | 09:42 PM
aklim's Avatar
Take the filter off and turn on the car. If fuel sprays, change filter. If not, try it a few more times and then go for the pump relay and finally the pump in the tank.
Do this outside and try not to smoke.
Old Sep 22, 2003 | 09:52 PM
Pro
Guest
Posts: n/a
"First off use your head"
Dude cmon why are you such a jerk? Give growing up a chance man.
And just because you want it to be the filter that is clogged doesnt mean you can stick a "99" percent on it. What the... 99? Are you for real? Recalculate. Sounds like "fuzzy math". You are still in highschool right? Taken algebra?
Old Sep 22, 2003 | 10:12 PM
DrDUKE's Avatar
The fuel pump goes out a lot on these. When you run em dry ( outa gass ) they will burn up quick. When you turn the key on you can easly hear it ( grrrr ) inside the car, and exspecially with your head in the trunk. No sound = Dead pump simple. You checked the Fuse right?
Old Sep 22, 2003 | 10:41 PM
aklim's Avatar
I run the tank from full to empty and several timess out of gas and the pump still went strong. Can't say it isnt burnt out in this case but would like to see if there is fuel pressure
Old Sep 23, 2003 | 08:35 PM
smurdogg's Avatar
thanks. it was the pump. thanks especially to the 99 percent guy.
Old Sep 23, 2003 | 11:19 PM
aklim's Avatar
Get the Walbro one. 255 L/hr and it should be fine. Make sure you have a gasket for the fuel tank holder ring and a couple of fuel tank straps. I hope you didn't have too much gas in the tank. It is a PITA without a shop to have it done. You have to drop the rear end.
Old Sep 24, 2003 | 06:40 PM
Zepher's Avatar
Just wondering if you changed it and now it works or what did you do to determine that it was bad.
Oh, and I second the Walbro 255. Get it if you haven't changed pumps yet.
ChrisFrez
Apr 5, 2015 05:54 PM
ChrisFrez
Mar 29, 2015 09:43 PM
ChrisFrez
Mar 22, 2015 07:00 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
ChrisFrez
Mar 22, 2015 09:12 AM
