Front panels missaligned.
Old Oct 8, 2003 | 03:00 PM
Z28James's Avatar
I have an 87 Z28 and the people who owned my car before me put a berlinetta front end on it because the original was messed up. The fenders just arent right on it :/ the drivers side doesnt seem to sit down low enough which causes the hood to pop up a bit, the other side seems as if the front is up a lil big. When you are in the car you can see the hood is warping a tad. Anyways, do you guys think this car was in an accident and the car was twisted or should i just keep messing with it to get the to line up right?
Another question, the car has no t-tops and i HATE it, perfect interior, so i was wondering..this is a LG4 car, how hard would it be to swap the drivetrain into another car with a better body and T-TOPS? Could I use everything from my car to make it all work?
Old Oct 8, 2003 | 05:18 PM
kevin 2.8's Avatar
first off the car was prbably hit in the front and they just had a berlinetta nose put on. depending how hard it was hit means if your quarter panels are out of whack.
try adjusting the hood stop heights to get them to line up.if you curious about how hard it was hit, take the nose off... its about 36 bolts going underneath the bumper to the ground effect rad air deflector, up inside the thin part of the quarter panel, and under the intake. then check out the rebar and metal bumper. the paint will have flaked off and rusted around any are that was hit. crap. i forgot to paint over mine. i bumped a pole last year.
and yes you could swap the drivetrain into a car with t tops.
you could find a v6 ttopped car cheap with a straight frame (cause it was a 6) and swap all the v8 stuff into it.
Old Oct 16, 2003 | 02:10 PM
Z28James's Avatar
Ouch, my front end is about an inch to the side. body shop priced me $150 to pull it and $50 for a new nose...this sound like a good deal???
Old Oct 16, 2003 | 02:59 PM
IROC-T's Avatar
That's not to bad if that is what you want to do,but why the new nose is the nose that is on there bad,or do you just want to change it back? What about alinment is it ok,have them check it out from front to back to make sure it is still square if it is not square dump it.
Old Oct 16, 2003 | 05:04 PM
Z28James's Avatar
Yeap the new nose just because i want to have the proper nose back on it.
Old Oct 17, 2003 | 11:28 AM
Shaun 90 Iroc's Avatar
Sounds good to me, but then again throwing $5000 into my car engine, paint, etc in the past year makes that look like chump change to me.. but its ironic because i now have NO MONEY and i am going for an interview today.
Alien
Jun 27, 2015 01:13 PM
cmyname1
Feb 19, 2015 08:38 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
MilkyClr69
Jul 29, 2002 10:01 AM
