A few electrical questions
Old Jul 11, 2005 | 08:30 PM
83CamShikwon's Avatar
Well my camaro had a headlight that didn't work, so I thought all it need to be was replaced. I replace it and it's still acting up, the light works normally but when I turn on the brights the outer driver side light doesn't turn on. I'm thinking it's a circuit problem, does anyone know how to fix this?
Another thing is my speedometer, my car recently got a new motor in it ( 5.7L Chevy 350ci V8 1979ish.. ) anyways, it's totally off, I'm pulling out of my drive way to go for a spin and it says I'm going 100, so if anyone could help me on that, thanks!
-Shikwon, 1983 Chevrolet Camaro 5.7L Chevy 350ci V8
Old Jul 11, 2005 | 09:42 PM
blown3rdgen's Avatar
Re: A few electrical questions
check the ground wire. I believe there should be 2 going to the rad core support.
'83 should be cable driven? Did you change tranny or rear? if so, simple gear swap in rear of tranny will solve it.
Matt
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Moshbmx1
Feb 17, 2015 10:51 AM
guyomatic
Sep 11, 2002 02:11 AM
