Fan Relay
Old Mar 14, 2004 | 04:17 PM
Ville H. Valo's Avatar
Fan Relay
Where is the fan relay on a 1992 z28?
Old Mar 14, 2004 | 07:09 PM
lordmetalz28's Avatar
passangers side , behind the battery , close to the radiator
Old Mar 14, 2004 | 10:52 PM
are you positive, i dont want to cut wires that are not correct
Old Mar 14, 2004 | 11:08 PM
PyRo9862's Avatar
And the haynes manual says...
Engine cords F and 8
Right side of the radiator support
Engine Codes G, H, S, and E
One the relay bracket at the left front of the dash
This is just what the book says, so don't come after me if its wrong
Old Mar 14, 2004 | 11:10 PM
PyRo9862's Avatar
I think yours is an F, 8th number in the vin.
Old Mar 14, 2004 | 11:31 PM
it is, and right as in passenger?
Old Mar 14, 2004 | 11:57 PM
IROC-T's Avatar
Yes ,right next to the battery. You are cutting wires,WHY?
Old Mar 15, 2004 | 02:06 PM
ok, i cant find it, wtf does it look like, im splicing wires for manual fan turn on.
Old Mar 15, 2004 | 02:19 PM
i just found out there are two fan relays and they are on the fire wall infront of the driver.
Old Mar 15, 2004 | 02:28 PM
IROC-T's Avatar
My bad, yours is on the inner fender up by the hood hinge should be a group of relays next to the master cylinder. Which one i'm not sure try unpluging them one at a time after you get the fans running. You do not have to cut the wire to put the manual switch if you pull the relay you can use stak-on spades and just plug in.
Old Mar 15, 2004 | 04:18 PM
rad
Old Mar 15, 2004 | 05:29 PM
how do i wire it to work with an LED switch? And i know i need to tap into the gray wire for the secondary, but what wire do i need to tap into for the primary, is it black/red. the switch has 3 prongs, labled 1, 2 and 3. thanks
-Ville
FoRd
Old Mar 16, 2004 | 04:28 PM
ok, today i shop class i got the primary fan hooked to a switch. Now i need to know, on the secondary fans relay, what wire is the ground? and is the secondary relay the one right next to the primary relay? thanks
Old Mar 16, 2004 | 11:23 PM
Thank you guys for all of the help, i found the other relay and i hooked up the second switch, but seriously, does anyone know how to hook up the LEDS. thanks
OutlawPerforman
Oct 30, 2017 05:40 PM
jerrysims71
Aug 15, 2015 12:47 PM
4586
Aug 2, 2015 01:45 PM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
