Extremely high idle
Old Dec 17, 2004 | 03:41 PM
NJSPEEDER24
Guest
Posts: n/a
Extremely high idle
I start the car up, and it jumps to 1500 and climbs gradually to 2000-2100 rpms.
I quickly shut the car off for fear that something could blow and it started to "deisel" of course..I can't let it idle like that but I have to warm the car up. Also,
I was able to put up with the 1500 rpm idle for 2 minutes in this New Jersey winter weather and after driving around everything was normal (idling at 600 at stops, and whatnot).
305 4bbl carb
700r4 trans
93k miles
Normally idles at around 600-900
EDIT: I searched before I posted this, but came up with two threads. Both went unanswered.
Old Dec 17, 2004 | 07:32 PM
85_305's Avatar
Re: Extremely high idle
Sounds like somehting with your timing is focked up. Either your Distributor, and maybe yur cam timing. (I am not POSITIVE that cam timing will cause that, but for sure Dist. timing will)
Old Dec 17, 2004 | 08:55 PM
NJSPEEDER24
Guest
Posts: n/a
Really? It's not missing or anything, car runs great (replaced dist., wires and plugs last year), just very high idle when I start her up in the mornings. When it's warmed up, like say 5 minutes of idle in the morning, it's back to normal. I was thinking more along the lines of the IAC..but wasn't sure.
Old Dec 17, 2004 | 09:18 PM
killer305's Avatar
is the choke getting stuck open?
Old Dec 18, 2004 | 10:25 AM
NJSPEEDER24
Guest
Posts: n/a
yeah I thought maybe it wasn't closing, which would explain why it's taking so long to warm up. Good call, I'll have to check.
Old Dec 18, 2004 | 10:27 AM
NJSPEEDER24
Guest
Posts: n/a
Originally Posted by robvas
Clean your IAC out. Check your TPS and set your base idle. Also, make sure your TB blades aren't all gummed up.
I'm thinking about it. I'm not sure about counts, and that sort of stuff. I'll have to look up the procedure somewhere (Aklim, I'm looking at you )
Thanks Rob
Old Dec 18, 2004 | 02:59 PM
85_305's Avatar
Ya, timing could cause the dieseling you are talking about; but here is another idea. Try unplugging the automatic choke, and THEN try starting the car. See if it runs right then, and then let us know.
Apr 3, 2015 10:54 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
Jan 23, 2015 01:13 PM
