Exhaust Manifold boltz
Old Apr 9, 2006 | 08:09 PM
Uc360's Avatar
i have a manifold bolt missing, it's the last bolt on the passenger side manifold by the "y" pipe does anyone know the size of this bolt, i took one of the other boltz out and tried to see if it would work but it didn't.....thanx
Old Apr 9, 2006 | 09:08 PM
Uc360's Avatar
Re: Exhaust Manifold boltz
does anyone have a pic of the 305 tpi exhaust manifold on the passangers side. a close pic of the back by the y pipe would help thanx
Old Apr 9, 2006 | 09:51 PM
2fbodies2NV's Avatar
If one of the bolts from another hole won't fit there's something wrong. Are you sure the bolt isn't broke off in the head? Try sticking a pocket screwdriver or a straight pick in the hole. See if it will go in as far as it does in the hole from the bolt you removed.
The bolt should be either a 10x1.50 metric or a 3/8x16 standard thread.
Old Apr 10, 2006 | 04:02 PM
Uc360's Avatar
how many bolts are there suppose to be on the passanger side exhaust manifold?
Old Apr 10, 2006 | 07:53 PM
Dave89IROC's Avatar
6 bolts
69z-28
Jan 29, 2016 10:46 PM
linz
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
