Exhaust idea
Old Feb 11, 2004 | 06:23 AM
ozz28's Avatar
Exhaust idea
I have a 84 z28 and i was thinking about doing an exhaust setup, from off of each headers a 2 foot straight pipe going into two mufflers with turn downs, i was wondeing is that possible, and does any one have that setup up already on there 3rd gen camaro
Old Feb 11, 2004 | 07:52 AM
305RSlc's Avatar
Yes that exhaust has been done a cagillion times on thirdgens. I personally don't like the turndowns under the car, cuz pipes out the back look way cooler. You could do it, but depending on what kind of muffler you go with you'd be sacrificing a little bit of ground clearance. There is a site that has a bunch of "true dual" exhaust setups on thirdgens. I'll see if I can find the link later on.
Old Feb 11, 2004 | 10:46 AM
aklim's Avatar
I don't care for the cool factor but I would question the setup because it sounds like it is going to vent under the car. I want exhaust as far from the car as possible because if you are idling, it could be a problem when the CO comes into the cabin.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Killer94z
Jan 13, 2015 12:06 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
