evil gremlin?
Old Dec 1, 2005 | 10:47 AM
Unix's Avatar
evil gremlin?
Hi !
I have a problem with my Camaro 5.0 TBI... the SES light is on and it reads code 43 - Low voltage at electronic spark timing circuit . What could be the problem The ignition module is ok, the knock sensor as well. The engine seems to be running ok. Does anybody have any suggestions on what it could be ?
thx for any info !
Old Dec 1, 2005 | 11:00 AM
bmillington's Avatar
Re: evil gremlin?
Is that the only code? I think thats the one you always get when the engine is not running (because the distbuter is not turning).
Old Dec 1, 2005 | 02:20 PM
Unix's Avatar
Re: evil gremlin?
that's the only code.. the engine runs fine. i suppose it's some kind of wiring issue, i recently swapped my V6 to V8 , and the wiring harness which i used was in a mess. but maybe u guys have some suggestions... tomorrow i'm gonna check the wires from the ignition module and knock sensor, make sure they are ok throught to the ECM. The Haynes repair manual has crappy electrical schematics and i don't have the Chilltons book :/
Old Dec 6, 2005 | 04:34 PM
Unix's Avatar
Re: evil gremlin?
ok, the problem has been localised to this module... what is it? What's it called?
Old Dec 6, 2005 | 07:50 PM
LoudmouthSS's Avatar
Re: evil gremlin?
had the same problem with my car...change out your knock sensor and it should go away. If you read in your hans manuel or w/e, it says if they ecm stops recieving a signal from the knock sensor, itll throw the code.
Old Dec 7, 2005 | 04:39 AM
Unix's Avatar
Re: evil gremlin?
like i said, my ignition module and knock sensor were ok, the problem was in this faulty module pictured above. What's it called??
Old Dec 7, 2005 | 12:04 PM
Re: evil gremlin?
thats your esc module
you can see it here...www.tpiparts.net
go to catalog then the ignition section..its in there (just in case you may need a new 1 and want gm quality parts)
o and sorry about the knock sensor thing, i didnt realize you had checked it already
Old Dec 7, 2005 | 12:36 PM
Unix's Avatar
Re: evil gremlin?
thx for the info, yes i need to buy a new one, right now my friend borrowed me his own
Old Dec 7, 2005 | 03:17 PM
Re: evil gremlin?
yup no problem
robcarnut
Mar 20, 2015 03:40 PM
num
Apr 7, 2003 04:39 PM
Frank99'z-28
Jul 16, 2002 05:58 AM
Frank99'z-28
Advanced Tech
