eradic idle and missing through out gears
Old Jan 31, 2009 | 11:53 AM
3864morgan's Avatar
i have a 87 IROC that when i start it it lopes like it has a cam in it but it doesn't after reving it up it finally idles just fine. When the car is cold it drives just fine as soon as it warms up it starts to miss and back fire when you apply a little pressure to the pedal it starts to kick and buck slam the gas and the car takes off. i just replaced the fuel pump yesterday and the problem is honestly a little worse i dont know if the timing or the advance is not going well or what any advice welcome
Old Jan 31, 2009 | 07:49 PM
MikeGyver's Avatar
Fuel injected, right?
Sounds like it could be a fueling problem while in closed loop, or a failing throttle position sensor.
check for vacuum and exhaust leaks, assure your o2 sensors are good
Old Feb 1, 2009 | 10:54 AM
Probably get better reuslts on the 3rd Gen engine tech forum.... I'll move the post there for you.
Old Feb 3, 2009 | 09:45 AM
teke184's Avatar
since you changed the fuel pump, would be logical to check the fuel pressure.
bout sounds like a sensor issue giving a bad signal.
first would be O2s
ChrisFrez
Mar 1, 2015 01:33 PM
Fatdog2
Feb 13, 2015 08:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
