Engine Swap 305 TPI to 327
Old Dec 29, 2007 | 01:32 PM
mike85z28's Avatar
I'm how advanced this question is but here goes.. I have a 1985 Z28 with a 305 TPI, and I want to replace it with a 327. What are some of the things I need to do and look for? I haven't done this before so any help will be great!!
Old Dec 29, 2007 | 02:54 PM
96capricemgr's Avatar
The engines are VERY similar should be a simple boltin.
One snag I see though is the TPI system is a very low rpm system and typically 327s want to rev. What are you planning to do with the computer?
Old Dec 29, 2007 | 03:04 PM
mike85z28's Avatar
The computer will be eliminated right, because the 327 will be carburated.
Old Dec 29, 2007 | 03:07 PM
mdacton's Avatar
If your swapping to the carb then no problem.
What trans do you have?
Old Dec 29, 2007 | 03:09 PM
mike85z28's Avatar
I'm just getting into all this stuff, is assuming its a 700r4 Do you think I'll need a stall converter?
Old Dec 29, 2007 | 08:08 PM
Andrew R's Avatar
A stall wouldn't hurt, especially with a high revving 327.
Old Dec 30, 2007 | 11:10 AM
mike85z28's Avatar
Also what are the options for my fuel pump??? Can I just suck through the one in the tank, or will I have to remove it???
Old Dec 31, 2007 | 03:42 PM
IROC-T's Avatar
You can use the one you have now, just go with the four port as mentioned in your other post. You will need to ajust the pressure down though.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rocketman051894
Jan 30, 2015 03:23 PM
hotrod 5210
Dec 22, 2014 07:28 AM
Carguy00
Aug 6, 2002 10:25 PM
