Engine Removal
Old Sep 22, 2003 | 02:11 PM
slayer6x6's Avatar
Engine Removal
Im pulling the engine out in my iroc and I had a few quick questions. The whole top end of the engine is already off including the heads. Where is the best spot to attach the chain for the cherry picker? Also, the bell housing bolts and motor mount bolts are removed, do I need to remove the flex plate bolts also? Will I run into any problems as far as the engine and trans being connected? Any tips are helpful, thanks!
Old Sep 22, 2003 | 05:01 PM
aklim's Avatar
How about the holes for the head bolts?
Old Sep 22, 2003 | 07:45 PM
Dave89IROC's Avatar
you have the mount bolts and bellghousing bolts out, how about the torque convertor to flexplate bolts?there are 3
use the head bolt holes to lift it
make sure to put a jack under the trans
Old Sep 22, 2003 | 09:45 PM
aklim's Avatar
You have to disconnect the flex plate from the TC to get it out. Support the tranny and make sure it is held in place by wire until the engine is back
Old Sep 23, 2003 | 01:47 PM
slayer6x6's Avatar
Cool, Thanks guys.
Old Sep 23, 2003 | 02:04 PM
99huggerorangeZ's Avatar
Question
why not just pull the transmission out with the engine?
Old Sep 23, 2003 | 08:34 PM
Rice Killer87's Avatar
if u dont need to,all it does it make a bigger mess and make things more of a PITA. ive been there already.
Old Sep 23, 2003 | 11:16 PM
aklim's Avatar
Take the tranny out. You'd have to remove the cooler lines (be careful or you break something. The are screwed into the radiator). Also the electrical harness, DS and try not to hit the radiator on the way out or in
Old Sep 24, 2003 | 11:17 PM
slayer6x6's Avatar
The radiator, harness, and drive shaft are already out. The only thing left in the engine compartment is the block, and the ac/heater plenum. I would have to put the bell housing bolts back in though.
Old Sep 25, 2003 | 12:52 AM
chevyman502bb's Avatar
k.....your parting out an iroc, and you have a 6 cyl camaro....obviously you f*cked up, whats the story here? what did you do to the poor 3rd gen?!?!
Old Sep 25, 2003 | 01:46 PM
slayer6x6's Avatar
http://web.camaross.com/forums/showt...hlight=wrecked
DirtyDaveW
Dec 1, 2016 05:37 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
centric
Aug 15, 2002 09:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
